Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-10-2009, 02:49 PM   #11
Oxnard Montalvo
Oxnard Montalvo's Avatar
Vehicle: 1966 Mustang GT Fastback
Quote:
Originally Posted by chewy1234 View Post
What about the gas in the tank. Is it best to fill it up or leave it close to empty? Either way using a gas stabilizer?
Use a stabilizer and fill it up. Run the car long enough to fill the carburetor bowls with stabilized gas. The gas will last through the winter.
The logic behind filling the car up is that if you leave a large amount of air inside the tank the humidity will change with the weather and condensation will form. Because water is heavier than gas this condensation will find it's way to the bottom of the tank and cause rust. This is one reason gas tanks rust out.
__________________
Oxnard Montalvo is offline   Reply With Quote
Old 10-12-2009, 01:00 PM   #12
1971mach1
1971mach1's Avatar
Vehicle: 1971 Mach1 351c Tremec TKO 5-speed- yea!
There is a product called "gas dryer" that removes the water from the gas.
I forgot the brands, but they are also found in the gas additives area of the auto store.
For humid climates, I'd recommend running some thru before storing it, especially
with old cars that don't have sealed evapoation system gas tanks.
1971mach1 is offline   Reply With Quote
351c, change, oil, stabilazer, stabol, storage, tremec
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
