Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-12-2009, 07:32 PM   #1
CAD
CAD's Avatar
Vehicle: 1969 Mustang Fastback
Default Sand blasters and media questions
Right now I'm shopping around for a sand blaster and wondering if anyone has any input? Just about the only decent choices locally are one like NAPA sells. I believe the model is Balkamp? They are the siphon type. I'm looking at one of the Eastwood pressurized sand/soda blasters right now. How much better are the pressurized type over the siphon ones?
Next question is what type of media do you guys use on your classic mustangs? I don't have soda blasting as an option where I'm at. The local abrasives place hasn't even seen soda before. Pretty much my options are Green Diamond, walnut, aluminum oxide, glass, maybe a couple other types.. What should I get? Should I use one type on frame and suspension and other thick metals and something else on the body skin?
__________________
'69 Mustang Fastback
CAD is offline   Reply With Quote
Old 10-12-2009, 07:53 PM   #2
cprstreetmachines
Blast what ever you want, other than the skin on the body. Qrtr's, roof, doors. You can hit the edges and about 1inch into a skin, but no farther.
__________________
turbocharged 1967 349 stroker
1/8 mile 6.966 @ 99.704 Rich
1/8 mile 6.47@107.6 Dustin 1.43 best 60ft
cprstreetmachines is offline   Reply With Quote
Old 10-12-2009, 09:09 PM   #3
chris66dad
1966 Ford Mustang
chris66dad's Avatar
Vehicle: 66 coupe
Soda blasting has many issues that can give you problems.
If your interested here is a pro painter forum (hotrodders) on the subject:
http://www.hotrodders.com/forum/once...ng-162700.html
Here is the Wiki article that is loaded with information, warnings and cautions:
http://www.crankshaftcoalition.com/wiki/Soda_blasting
Read and then make a decision...
Good luck and BE Safe
Ron
__________________
Ron
http://chris66dad.tripod.com/
A code 66 coupe
289 4v, Roller Rockers, Electric fan
Performer & 650 Edelbrock
MSD ignition
Tri Y into 2.25 Shelby side exhaust
T5 conversion
Hydraulic clutch
CSRP Disks
chris66dad is offline   Reply With Quote
Old 10-12-2009, 10:16 PM   #4
Tony R
Tony R's Avatar
Vehicle: 65 mustang 91 exploder 94 F150
I used the biggest blaster that harbor freight sells. I also used sand. It was medium playground sand IIRC. I did the entire car. If you are careful you wont warp your panels.
Tony R is offline   Reply With Quote
Old 10-12-2009, 10:32 PM   #5
CAD
CAD's Avatar
Did you get the siphon or pressure from harbor freight? How much have you used it? Any problems?
__________________
Old 10-12-2009, 10:51 PM   #6
Jaded
Vehicle: 1968 Ford Mustang Coupes
I'm using Eastwoods blaster with the soda conversion kit. The only drawback I've had is not enough air compressor. It requires 7 scfm @90psi, and mine couldn't keep up with the blaster. Otherwise it works fine.
My neighbor uses the harbor frieght blaster with play ground sand, something I'm not willing to do because of the hazard, and the ability to quickly warp a panel. Besides, I don't have acres of land in the middle of nowhere to do this like he does.
I'm looking at an 80 gallon compressor now that is more than double the needed scfm rating at 90. That outta take care of painting this beast too.
__________________
Signal Flare Red 1968 Coupe, 302, Automatic.
Project 1968 Coupe, 302, Automatic, lowered.
2002 F350 Dually Crew Cab, 7.3L, Banks Kit
Jaded is offline   Reply With Quote
Old 10-12-2009, 11:46 PM   #7
Tony R
Tony R's Avatar
I have the pressure tank. I also did it in the garage. i will pay next time to avoid the mess. Even with draping plastic around the garage it still trashed my garage.
Old 10-13-2009, 12:15 AM   #8
photocliff
1969 Ford Mustang
photocliff's Avatar
Sandblasting causes metal warp? How? Is the presure causing the body to dent in.
__________________
Go Baby Go
photocliff is offline   Reply With Quote
Old 10-13-2009, 12:30 AM   #9
CAD
CAD's Avatar
photocliff, it's the heat that causes warpage. The thinner the metal the higher the chance.
__________________
Old 10-13-2009, 12:33 AM   #10
CAD
CAD's Avatar
Tony, how well did you seal around the car? I'm thinking of making a "booth" of plastic around it. Top, bottom, & sides. That way I should be able to reuse some of it too.
__________________
98665, abrasive, albuquerque, beauty, black, blaster, diamond, green, media, nm, play, playground, sand, vancouver, wa
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
