I checked the floats. One was good and the other was off 1/4 inch on the hang test. I corrected that and added the silver (stronger) step up springs. I retarded the timing a little. Test drive will have to wait until Thursday. Keeping my fingers crossed.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
66 Coupe
289
Auto
Hooker Comp headers
Flowmaster dual exhaust
Crane RV cam
Edelbrock Performer 289
Edelbrock 600
You are both right. I did mess that up. I put in the 1455's and left the 98 jet which made it really rich correct? What if I put in a 95 jet and went with the 1455? The chart on the Edel site says that is 6% leaner in the cruise mode and the same in power.
__________________
66 Coupe
289
Auto
Hooker Comp headers
Crane RV cam
Edelbrock 600
that's correct
stock is baseline (1459 rods and 98 jets)
changing only rods to 1455 and leaving the 98 jets in there will richen up power and cruise
if you now leave those rods in there and change both primary jets to 95, you will have the same power A/F, but cruise A/F will lean out.
(at least all that according to the edelbrock owners manual)
Kalli
__________________
1964 1/2
302ci, Edelbrock RPM heads and cam, 650 speed demon, Long Tube headers and Flowmaster 40s
Quick Performance Racing 9" rear, Moser axles, 3.5:1 trac-loc from FRPP and T5 transmission.
CSRP disc brakes front and FRPP discs back. http://www.gascc.ie
Ok. Here's what I did today. Replaced the jets to 95's put the 1455's in, reset the timing to 10 d BTDC, put the accel pump in the lowest hole. It still falls on its face. I checked the timing and at 3000 rpm it is only advancing to 20 ish. It should go higher than that right?
__________________
66 Coupe
289
Auto
Hooker Comp headers
Crane RV cam
Edelbrock 600
I did disconnect it. Should I put a cap on the vac port on the carb when setting it? If that is all that it shows, what do you think could be the problem?
__________________
66 Coupe
289
Auto
Hooker Comp headers
Crane RV cam
Edelbrock 600
Yes, you need to cap that vacuum port when you pull the hose off. Sometimes the easier way to do it is to pull the hose off the distributor, then plug it with your finger or a screw.
That said, the problem is your distributor advance springs/stops. I'm not sure how the mechanical advance limiter is set up on the stock distributor, but you can change the curve by changing the springs on the centrifugal weights.
Before doing anything else, make sure the weights are clean and free of any bind.
__________________
Tad H.
'67 Fastback
331 stroker
I will check those. Actually, that's all that's left in there after putting the Pertronix 3 in. It is different than the Per 2. You take everything out and the 3 screws in where the points plate was.
__________________
66 Coupe
289
Auto
Hooker Comp headers
Crane RV cam
Edelbrock 600
