Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-13-2009, 04:29 PM   #1
bookzguy
Default Will these rims/tires work?
...on a 66 Mustang coupe with grab-a-trak 1" drop plus shelby drop and 1" lowering blocks in the rear. Also half a coil cut on the 620 springs.
Set of 4 Ford Racing Mach 1 17" magnum wheels/tires
* Fits 1994-2004 Mustangs
* 5-lug, 5.72" backspacing
* Bolt pattern 5x4.50in. or 5x114.3mm
* 17"x8"
Set includes 4 wheels with a few minor blemishes here and there.
Also includes 4 tires, 245/45ZR17; 2 of which have over 90% of tread, other 2 need replacing.
Can I keep the two good tires in the rear (245/45/17) and replace the front with smaller tires to fit?
__________________
2000 Mustang GT 5-speed
bookzguy is offline   Reply With Quote
Old 10-13-2009, 04:59 PM   #2
Starfury
In a word, no. You'd have to do some serious massaging to the front fenders on a 65-66 to cram 8" wheels up there. The backs would probably fit if you rolled the fenders, but not the front.
Plus, you'd need wheel adaptors to achieve proper backspacing.
__________________
Tad H.
'67 Fastback
331 stroker
Starfury is offline   Reply With Quote
Old 10-13-2009, 05:07 PM   #3
bookzguy
I forgot to mention that my front and rear fenders are rolled.
You can't put an 8" rim in the front of a 66?
__________________
Old 10-13-2009, 05:12 PM   #4
Starfury
Like I said, not without significantly altering the front fenders. Rolling the fender lips won't be enough. These cars just weren't designed for wheels/tires that wide. 7" will fit (but may rub, depending on tire size), but not 8".
__________________
Tad H.
'67 Fastback
331 stroker
Old 10-13-2009, 08:23 PM   #5
roka-88
Vehicle: '66 Fstbk
I fit 16x8's and 17x8's 4 1/2 backspace with no problem on my '65 and '66. I didn't even have my fenders rolled on the '65 and the 17x8's fit great.
roka-88 is offline   Reply With Quote
Old 10-13-2009, 08:29 PM   #6
roka-88
Vehicle: '66 Fstbk
I'm not sure if 5.72 backspacing will make a big difference but i know the 16x8's and 17x8's with 4 1/2 backspacing will fit like a champ! with or without rolled fenders but your better off rolling them to avoid rubbing on corners..
Old 10-13-2009, 11:41 PM   #7
BA Mustang
ROTM Moderator
1967 Ford Mustang
BA Mustang's Avatar
Vehicle: 1967 Mustang Coupe
Send a message via AIM to BA Mustang Send a message via Yahoo to BA Mustang
You will have to use wheel adapters. There is someone on here with those rims on his 65-66.
__________________
ROTM November!
Own a red mustang join this group: Red
Own an I6 mustang join this group: I6
BA Mustang is offline   Reply With Quote
Old 10-14-2009, 01:44 AM   #8
Starfury
Hmm. How much do they rub?
__________________
Tad H.
'67 Fastback
331 stroker
Old 10-14-2009, 08:20 AM   #9
dodgestang
Vehicle: 1965, Mustang, Fastback
Quote:
Says you.
My 245 40 17s on 17x8 with 4.75 backspacing fit just fine on the front of my 65 mustang. And I don't even have my fenders rolled.
Please note I do run -2.5 in the 'ole alignment department though and have the shelby drop on the upper arm
As originally mentioned however...those wheels will not work without the use of adapters to adjust the backspacing and I do not like the idea of 245 45 17 on the front given my knowledge of my own setup and where it sounds like his ride height is at. I also successfully ran 235 45 17 for years on the front on my 8 inch rim so that might be a better fit if your stance is as low as it sounds like.
__________________
Nick
65FB 408c AOD D.T.
11.521 at 118.85 (Best ET to date 11.45 at 118.85)
http://www.youtube.com/watch?v=c60rI5RWnJw
dodgestang is offline   Reply With Quote
Old 10-14-2009, 10:59 AM   #10
BA Mustang
ROTM Moderator
1967 Ford Mustang
BA Mustang's Avatar
The members name on here is sixt5.
__________________
ROTM November!
17, 17x8, 1968, 23545zr17, 65, 66, 8, bolt, drop, fastback, fit, mustang, pattern, rim, rims, shelby, wheels, widest
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
