Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-15-2009, 04:13 AM   #11
tx65coupe
tx65coupe's Avatar
Vehicle: 1965 Ford Mustang
I don't like the Grant wheels either.
Personally, I look the stock wheel.
That Shelby wheel is cool. Can you get one like it that not got the woodgrain?
I agree, you will need a steering wheel puller. Several years ago when the company my Dad works for had a small machine shop, we made our own that looked almost identicle to that one in the picture.
tx65coupe is offline   Reply With Quote
Old 10-15-2009, 06:38 AM   #12
2+2GT
Vehicle: 66 Mustang 2+2GT
Well, I have the factory style "wood" wheel in my car. The 65-66, 67, and 68 factory "wood" wheels are all available, new in reproduction.
2+2GT is offline   Reply With Quote
Old 10-15-2009, 06:45 AM   #13
kalli
Vehicle: 1964, Ford, Mustang
you can always make your own puller. I fabricated one in 10 mins. all you need is a straight angle, a nut, 3 bolts. a drill and a welder
lemme check if I still have a picture of that thing ...
__________________
1964 1/2
302ci, Edelbrock RPM heads and cam, 650 speed demon, Long Tube headers and Flowmaster 40s
Quick Performance Racing 9" rear, Moser axles, 3.5:1 trac-loc from FRPP and T5 transmission.
CSRP disc brakes front and FRPP discs back.
http://www.gascc.ie
kalli is offline   Reply With Quote
Old 10-15-2009, 09:48 AM   #14
SJs 66coupe
SJs 66coupe's Avatar
Vehicle: '66 Mustang Coupe
I pulled mine off a while back to replace the turn signal harness.
The part that was hard was getting the bolt off the center of the wheel. I finally had to get a breaker bar and beat the crap out of it with a hammer to get it to break loose after hosing it down with WD-40 and letting it soak in for 30+ minutes.
You will need the wheel puller also...can be picked up fairly cheap at the local O'Reily's or similar place.
$60 / hour is about the going per hour labor rate around here for shops so the price is fair enough.
__________________
SJs 66coupe is offline   Reply With Quote
Old 10-15-2009, 05:51 PM   #15
MetalEd
Vehicle: 1964 170 I6 Coupe
I purchased a 2 bolt steering wheel puller for the original Mustang wheel, now I need the 3 bolt puller to re-seat my grant wheel (slightly off).
Just wanted to mention it since I got the new catalog today. Harbor freight has a 2 & 3 bolt/yolk (46 pc Bolt puller set) puller that works on Steering wheels, harmonic balancers, gear pulleys and crankshaft pulleys for $9.99. Looks like it works with sae and metric. for harbor freight good price and not much that can go wrong with it. Item 37824-1RHH
__________________
Ed - 64 Coupe I6 170ci
20 years late getting my dream car, but my son driving it to his high school is just as wonderful!
MetalEd is offline   Reply With Quote
Old 10-16-2009, 01:30 AM   #16
Galactusz
Thanks guys...much appreciated for all your posts.
Even with the puller...I'm a little intimated.
But I'll give it a go.
Thanks again fellas!
__________________
Hector
Galactusz is offline   Reply With Quote
Old 10-16-2009, 01:36 AM   #17
Galactusz
Quote:
Originally Posted by 2+2GT View Post
$5. Not heavy duty, it would wear out in regular use, but it'll last you forever.
http://www.northerntool.com/webapp/w...6123_200396123
Thanks for that link!
__________________
Hector
Old 10-16-2009, 09:44 AM   #18
SJs 66coupe
That's part of the fun, figuring things out and the satisfaction of having done the job yourself.
These old cars are pretty straight forward and easy to work on. I won't even open the hood on my '07 Explorer but I've been surprised at what I've been able to figure out on the '66 Coupe.
__________________
Old 10-16-2009, 11:10 AM   #19
oldrock
oldrock's Avatar
Vehicle: 1969, mustang, coupe
I just recently changed out the wheel on my 69 coupe and went with a grant wheel. I have no beef with the grant wheels as long as you don't pick the one with that hollow cap with teh mustang pony on it. My buddy put one of those on his 65 and it sucks! The center cap is help on by a cheap cardboard ring and his falls off any time he uses the horn. That wheel seems to be very popular with mustang owners but I would suggest going with one of the billet center cap wheels instead. THey are much better built and basically cost the same as the cheap one. Installation was a snap by the way. My only problem is I had to do mine twice because I had it slightly off centered the first time I did it. To avoid my mistake, make sure your car has wheels straight ahead when you park it to do the job. OH and +1 remove the battery cable before starting. I didn't and the random honks and sparks when the connection touched certainly got my attention till I went and disconnected teh cable.
oldrock is offline   Reply With Quote
Old 10-16-2009, 05:10 PM   #20
Galactusz
Yes...I have the one with the hollow cap with the Mustang on it...and yes...it keeps falling off...lol.
This is the one I have now (the cap has fallen off since)...
This is the one I'm going to replace it with...
I know both steering wheels are cheapies...but I don't want to spend that much money...so I'll give this new one a try...if the horn cup doesn't hold up like the other one...then I'll get one of the higher-end steering wheels.
__________________
Hector
1965, changing, gap, mustang, steering, sterring, wheel, wheels
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
