Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-17-2009, 01:25 PM   #1
nealro
Default axle retainer bolt size
Hey all, haven't been on here for a while but finally back to work on the old clunkers. I'm actually working on a '71 F100 but have a Mustang question that will help with my truck.
I had to cut off a couple of the axle retainer bolts on the rear-end of my truck (9" )and need replacement bolts. The only place I can find the bolts is from CJ Pony Parts, the problem is they don't list the sizes and they didn't know if the items they sell are 3/8" or 1/2" bolts, they only sell them by year. ie a kit for a 67-68 mustang or 69-73 mustang. My '68 Mustang is no help... it has the 1/2" bolts and big bearings but it does not have the stock rear installed and I'm not sure what it came out of... Can anyone out there tell me if either the 67-68 or 69-73 Mustang would have had the big bearing flange and 1/2" axle retainer bolts? Or direct me to somewhere else that sells these oddball bolts?
__________________
~nealro~
'68 coupe
nealro is offline   Reply With Quote
Old 10-17-2009, 10:54 PM   #2
Toploader Pony's
Toploader Pony's's Avatar
Vehicle: '68 Mustang Fastback, 351C, toploader '66 Mustang Ragtop
Hey, I'm new to the site !
If its a 28 spline small type, then I believe its a 3/8 fine thread. If its a 31 spline large type, then its a 1/2 fine thread.
anything you want to know about Ford 9" rear ends can be found here at this website http://www.kevinstang.com/Ninecase.htm
if you page to the bottom, they list about 10 other sites for more indepth information.
Good luck !
__________________
"We ALL to have to eat a little S..T now and then............but I've learned not to swallow"
'68 Fastback, 351C, 4-speed toploader
'66 Ragtop, 289 4-v, 4-speed toploader
Toploader Pony's is offline   Reply With Quote
Old 10-19-2009, 02:46 PM   #3
nealro
Yea, I've got that website bookmarked and reference it all the time, in this case however it doesn't have the specific info I need. I already know what I need - I need the 1/2" bolts. I was trying to find out what year mustangs would have the 1/2" bolts stock so I can order some.
I may have misspoken about big bearing/small bearing, I was actually referring to the housing ends/backing plate flange size.
__________________
~nealro~
'68 coupe
Old 10-20-2009, 12:21 AM   #4
67t5ponycoupe
1967 Ford Mustang
Vehicle: 1967 GT Coupe
All the rears I have taken apart have used 9/16 sockets on the nuts which would make the bolt a 3/8. I can't imagaine anything using a 1/2 bolt that would make the nut size 3/4. that is crazy big.
67t5ponycoupe is offline   Reply With Quote
Old 10-20-2009, 03:21 AM   #5
1965screamer
1965screamer's Avatar
Vehicle: 1965, Ford, Mustang
Quote:
The 'big bearing' 9 inch uses bigger bolts around the bearing retainer. I thought the same as you did until last summer when my 9/16 socket wouldn't fit
1965screamer is offline   Reply With Quote
Old 10-22-2009, 11:04 PM   #6
nealro
Well, I was never able to confirm what Mustangs would have the 1/2" bolts but I found the 1/2" bolts that I need at Jeff's Bronco Graveyard (http://broncograveyard.com/)
__________________
~nealro~
'68 coupe
axle, bearing, big, bolt, bolts, ends, ford, housing, inch, retainer, size
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
