Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-21-2009, 10:38 AM   #21
chris66dad
1966 Ford Mustang
chris66dad's Avatar
Vehicle: 66 coupe
Quote:
Originally Posted by nba1341 View Post
Here is what I got for alignment specs
Front roadside 1/4 positive both sides
canister 1 1/2 - 2°
16 tow in
any help?
You DON'T want any POSITIVE CAMBER, especially with wide tires. 0 to -.5 will make it corner better because it will keep the tire surface flat in a turn.
The caster setting looks ok with POSITIVE 1 1/2 to POSITIVE 2 degrees
I think you need to look really good at the steering and suspension for worn or sloppy parts to correct you car changing direction with a bump though.
From Daze site for front end alignments:
1960-1966 Mustang and Falcon
Performance Alignment with or without UCA drop”.
These specifications are in order of importance.
1. NO more than .25 degrees difference between driver’s side and passenger’s side.
2. +2.0 to +3.5 degrees caster.
NOTE: for cars with Adjustable strut rods. Please attain as much caster as possible using the shims (at least 1.5 to 2.0 degrees), and then use the adjustable strut rods to increase the caster and make the sides the same. Also, please note that the caster difference between the driver’s side and passenger’s side needs to have no more .25 degrees difference prior to the adjustment of the strut rods.
3. -.5 to 0 degrees camber. No positive camber, please. There is no problem having a slight variation from driver’s side to passenger’s side to account for the crown in the road.
4. 1/16" to 1/8” toe in
Good Luck and be Safe
Ron
__________________
Ron
http://chris66dad.tripod.com/
A code 66 coupe
289 4v, Roller Rockers, Electric fan
Performer & 650 Edelbrock
MSD ignition
Tri Y into 2.25 Shelby side exhaust
T5 conversion
Hydraulic clutch
CSRP Disks
chris66dad is offline   Reply With Quote
Old 10-21-2009, 10:55 PM   #22
Tims65
canister 1 1/2 - 2°
16 tow in
Thanks for posting the alignment specs. I reading them as:
Camber: +.25*
Caster: +1.5* - +2*
Toe In - 1/16"
First the alignment shop should have been able to give you a computer print out of the starting and finshing alignment specifications. There should be camber, caster and toe settings for both the right front and left front wheels.
Now for your settings, Ron's information is on the mark.
Toe settings:
First to help you understand toe settings, here is a brief description:
Toe would be the angle of the tires as rotated on a vertical axis. Toe-In would basically be pigeon toed and Toe-Out would be duck-footed. Your toe-in setting of 1/16" is within the acceptable range.
Camber settings:
Camber is how much the tire/wheel is tilted. If the tires/wheels are tilted in at the top, as you are looking straight at the front of a car, this would be negative camber.
So Negative camber would look like this: /-----\
and Positive camber would look like this: \-----/
Your positive camber settings are contributing/causing the tires to rub the fenders. Like Ron said, you need to change the positive camber to negative camber.
Caster settings:
Caster is the angle of the steering axis. If you were to draw a line through the ball joints on the upper and lower control arms you would have 0 degrees Caster. If the lower control arm is moved toward the front of the car you would be increasing positive caster. Like I posted earlier - The easiest way to describe it would be to think of a bicycle and angle of the front wheel fork. If the fork that connects the handle bars to the front wheel were to be straight up and down (0 degrees Caster) you would constantly need to steer to keep the bike going in a straight line. Now if the front fork were installed at an angle (think chopper - Positive Caster), you could take your hands off of the handle bars and the bike would continue to track in a straight line.
The Caster settings that you posted would be acceptable, but I am surprised with the way you are describing the manners of your car at highway speeds. I would go back to the alignment shop (or another alignment shop) one more time and ask them to:
- change the camber from the positive setting to between 0.25* and 0.50* Negative camber
- increase the Caster to at least 2.0* Positive Caster.
There are two ways to set Caster on our early model Mustangs. One way (the easy way) is to pull the front wheels forward by tightening down on the strut rods as much as possible. The other way is by adding shims to the front mounting bolt of the Upper Control Arm. The problem with adding shims to the control arms, is it changes the camber setting, so there is a lot of back and forth and trial and error to get all of the settings correct.
A lazy shop (or one that does not know how to properly align an older car) will crank down on the strut rod and say "That's all of the Caster that is available". You need to find a shop that knows older cars and is willing to put in the time and effort. It will, also, cost more then aligning a modern car.
Good luck and keep us posted.
Tim
__________________
65 2+2
347 - Retrotek EFI, 371 fwhp
T-5
9" with 3.55's & T-loc
4 wheel disc brakes
17" AR CL-205s, 225/45 & 245/45
TCP/GW suspension
Tims65 is offline   Reply With Quote
Old 10-22-2009, 12:31 AM   #23
groho
just a courtesy note, the current issue of mustang monthly speaks specifically about front end alignment. that neg toe is not helping your situation at all, which means your tires are pointing outward, duck feet.
groho is offline   Reply With Quote
Old 10-22-2009, 05:09 AM   #24
tx65coupe
tx65coupe's Avatar
Vehicle: 1965 Ford Mustang
I agree with groho. You do not want duck feet. That will cause handling problems and waste fuel in the process.
tx65coupe is offline   Reply With Quote
Old 10-22-2009, 06:44 AM   #25
Tims65
I think he posted that his toe settings are 1/16" toe in.
You measure toe as either in (pidgeon toed) or out (duck footed). 1/16" toe in, is a great setting for a street car.
Tim
Old 10-22-2009, 07:43 AM   #26
tx65coupe
tx65coupe's Avatar
I guess I overlooked that. I was just going by what he just said. The slight tow in is good.
Old 10-22-2009, 07:44 AM   #27
tx65coupe
tx65coupe's Avatar
I wonder if there isn't something wrong with one of the tires. Where the tires ever driven on when the alignment was out of whack.
Old 10-22-2009, 07:42 PM   #28
Tims65
nba1341,
Can you list your front end componenets? Do you have any non stock items?
- Upper Control Arms
- Lower Control Arms
- Strut Rods
- Spindle (especially if you have a brake swap that requires the Granada style spindle)
Tim
__________________
65 2+2
T-5
4 wheel disc brakes
TCP/GW suspension
Old 11-02-2009, 11:40 PM   #29
nba1341
Vehicle: 1965 mustang fastback
Ok I will get this information this week
as for the tires
I crashed into a curb and killed one of my rims and front tires (passenger side) 2 years ago and the upper control arm broke
that was replaced and currently I have 2 different sets of tires front and back
also the treading on one is like straight and the other has a weird design in it
Could this be also the cause of the problem that the treading on the tires from the front and back is completely different?
and yes balding is seen on the insides of the tires as they were driven on for a while when the alignment was out of whack.
I know that all my suspension components are stock (replaced with newer parts) but they are pretty much direct replacements
as for the brakes i need to find out on that because I did get a front disc brake kit
__________________
1965 mustang fastback 302
nba1341 is offline   Reply With Quote
Old 11-03-2009, 12:08 AM   #30
hiboostwoody
hiboostwoody's Avatar
Vehicle: 1967 Fastback
Has anyone checked to make sure you don't have a broken belt in one of your front tires? That will cause a car to be all kinds of unstable.
__________________
Absolute rule number one: If it has tires or tits, your going to have trouble with it.
hiboostwoody is offline   Reply With Quote
1966, 2005, 2010, axis, bushings, camber, fender, hits, inclination, mustang, rod, settings, shimmy, sterring, strut, tire, wheel
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
