Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-22-2009, 01:29 AM   #1
MonsterBilly
1966 Ford Mustang
Vehicle: 66 coupe
Default Im thinking about a 40-60 shot of NOS
So i have a fairly strong bottom end. I am thinking about a small shot of NOS. who has the best kit. i see a bunch of them, i dont think there is really i big diff. is there?
This will only be to screw around with. Not an everyday thing btw.
__________________
66 coupe, 289, T5, Stealth Intake, Holley 670 Street Avenger, Centerforce Clutch, Headman Headers, Pypes Exhaust, Lunati Cam
MonsterBilly is offline   Reply With Quote
Old 10-22-2009, 02:00 AM   #2
1966_FE
1966_FE's Avatar
Vehicle: 1966, Ford, Mustang
I have a NOS Sniper kit, it's adjustable from 75-150 hp, I think..... I can't remember. Anyway, it's a simple plate system, not much to it. At 75 hp you should be fine, just remember to get enough fuel to it (run a seperate fuel line and pump) just to be on the safe side. Hope that helped.
__________________
1966 Coupe
Engine: 428CJ
Trans: Tremec TKO 600
Rear End: 9" w/ trak loc
1965 Coupe
Engine: 289 C Code
Trans: Borg Warner T5
Axles: 31 spline Dutchman
1966_FE is offline   Reply With Quote
Old 10-22-2009, 05:07 AM   #3
tx65coupe
tx65coupe's Avatar
Vehicle: 1965 Ford Mustang
Personally, I would not mess with nitrous. I don't want anything to do with it. I have seen way too many people trash their engines with it.
Also, its not always there. In my opinion, its artificially making a car faster than it really is. Besides that, you have to keep paying to refill the bottle.
tx65coupe is offline   Reply With Quote
Old 10-22-2009, 07:17 AM   #4
kalli
Vehicle: 1964, Ford, Mustang
NOS would be a great little piece of fun and I always thought abaout it, but I'm too scared as I'm afraid I'll ruin the engine running lean or too much timing
__________________
1964 1/2
302ci, Edelbrock RPM heads and cam, 650 speed demon, Long Tube headers and Flowmaster 40s
Quick Performance Racing 9" rear, Moser axles, 3.5:1 trac-loc from FRPP and T5 transmission.
CSRP disc brakes front and FRPP discs back.
http://www.gascc.ie
kalli is offline   Reply With Quote
Old 10-22-2009, 08:17 AM   #5
LCC
LCC's Avatar
Vehicle: 68 Fastback
NOS is safe when you use it properly. Lots of guys have used it for years and continue to use it. Read up on NOS or ZEX kits.
__________________
68 Mustang Fastback
Lentech AOD, 357 SBF, Vortec S/C, F.A.S.T. EFI
First time out Video
Road Test Video
LCC is offline   Reply With Quote
Old 10-22-2009, 11:10 AM   #6
urban_cowboy
1969 Ford Mustang
urban_cowboy's Avatar
Vehicle: '69 Mustang Mach1
As said above, nitrous is a very good power adder if 1. you run the correct AFR 2. you have strong enough parts to survive the extra power 3. you have plenty of fuel flow 4. your suspension and traction can plant the extra power. If you do not meet those requirements, it is going to be bad. Most people who have had bad experiences with nitrous, ran too lean, or broke parts b/c they could not handle the power...both of which are a problem when running NA too, but nitrous gets blamed due to ignorance. Be smart and set it up right and it can be lots of fun.
__________________
"Yeah, were runnin a little bit hot tonight. I can barely see the road from the heat comin' off of it." Van Halen
urban_cowboy is offline   Reply With Quote
Old 10-22-2009, 01:47 PM   #7
cprstreetmachines
Stock bottom end, ran that 100 shot for 5 years without any problem. Above posters are right though. Follow the directions on the pressure and jetting, and you will be fine. I never even checked my AFR to be honest. Ran it exactly how they said. Mine was the Super power shot. Only thing I've seen change of the years that would sway me is a kit that had stainless jets, not brass.
__________________
turbocharged 1967 349 stroker
1/8 mile 6.966 @ 99.704 Rich
1/8 mile 6.47@107.6 Dustin 1.43 best 60ft
cprstreetmachines is offline   Reply With Quote
Old 10-22-2009, 02:14 PM   #8
Iskwezm
Vehicle: 1965 Mustang Fastback
Send a message via Yahoo to Iskwezm
I also ran a 125 super powershot on my mildly built stock bottom end 289 and it took it to the 11's. I worked for NOS for a while so i was able to learn what to do and not to do. I didnt run a separate fuel system, just a single Holley Blue pump.I used the 125 HP jest and never had a problem. My old DD 94 GMC truck used a 150 shot on a bone stock 5.7 for years and never had a problem.My Banshee quad had a Sneaky Pete set up on it.My buddy runs a 150 shot on a Kragen replacement 350 in his elco. Ive never had any issues once it was jetted right.
__________________
Sound Desicion Car Audio & Peformance
[IMG]sig is gone for the whiners[/IMG]
Iskwezm is offline   Reply With Quote
Old 10-22-2009, 03:40 PM   #9
eZ
Thats just because they are easy to hook up and poeple that dont know what they are doing run a nitrous button.
example; guy hooks up a nitrous system to his stick shist pos eclipse. runs the system on a button. hes racing hits the button and when he shifts he lets up off the gas while his finger is still puching the button...boom!
run a WOT switch so that the system can only be activated in WOT that way the motor is getting enough fuel. running nitrous lean is ok but nitrous rich is catastrophic. make sure the fuel selenoid is getting approx 6psi freeflow. if your getting enough fuel nitrous can be very reliable. On 100 shot there is no reason to run a stand alone fuel system, just a good pump.
__________________
eZ is offline   Reply With Quote
Old 10-22-2009, 07:39 PM   #10
cprstreetmachines
Quote:
Hence his name ladies and gentleman. lol
__________________
50, 75150, ford, kit, nos, pete, shot, sneaky, sniper
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
