Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-22-2009, 08:54 PM   #1
Nick.Simonds
Nick.Simonds's Avatar
Vehicle: 65 Coupe
Default 351w flywheel question
Ok I think I have this down just need to be 100%. The engine shop is tearing into my engine rebuild but they hit a road block, the fly i brought 50oz. This is a 79 351w with a '90 T5.
- ALL 351w where 28oz, and 289 where too UNTIL ~1980 when they changed to 50oz. Correct?
- I need a 157 tooth because a 164 will not physically will inside of the bell, or so I've heard. Correct?
Summary: Will a 157 tooth 28oz work for a '79-80 351 with '90 T5?
Thank guys.
__________________
Nick.Simonds is offline   Reply With Quote
Old 10-22-2009, 09:05 PM   #2
Adrenolin
1967 Ford Mustang
Adrenolin's Avatar
Vehicle: 67 Ford Mustang
I've got a 79 351w myself in our 67. Yeah you'll need a 28oz flywheel. I ditched the original housing for a Lakewood housing and went the 164 tooth myself with a 4-speed toploader. Cant comment in regards to the T5.
What size clutch are you using?
Are you converting over to a roller setup?
__________________
GT 351 - 67 Mustang / 68 Shelby Conversion (GT351.net)
Modified 351w, 4-Spd Toploader, Coil-Over Suspension, Power R&P, 4-Wheel Disks,
Currie 9" Rear with 3.25 & TrueTrac, Ron Francis Wiring, Vintage Air, Intermittent Wipers,
Sequential Tail Lights, Power Windows & Locks, Rear Window Defrost, Heated Seats....
Oct 2009 Mustang Forums ROTM Winner!
Adrenolin is offline   Reply With Quote
Old 10-22-2009, 09:10 PM   #3
Nick.Simonds
Vehicle: 65 Coupe
I do not know what size clutch. I have a setup that came with the T5 supposedly with only a few hundred miles on it.
Haven't planned on going roller, but seeing as this project will be slow going over the next or so I defiantly have time to keep my options open.
__________________
Old 10-22-2009, 09:33 PM   #4
Adrenolin
1967 Ford Mustang
Adrenolin's Avatar
Highly suggest going with the roller setup. The 2 small holes in the block valley had me worried until I actually grabbed the drill. Buy a new proper sized bit and a set of bit depth rings to ensure you drill the exact depth and no deeper. Use a tap to thread the 2 holes and your done. Took me about 10 minutes. Don't forget to tape off the entire valley except for the areas to be drilled. I also used a shop vac on the area while I was drilling. Kept it all very clean.
__________________
Old 10-22-2009, 09:43 PM   #5
Nick.Simonds
Vehicle: 65 Coupe
Ohhh that roller haha. Yes that is going in. Haha I thought you were talking about clutch pedal.
__________________
Old 10-22-2009, 09:49 PM   #6
Adrenolin
1967 Ford Mustang
Adrenolin's Avatar
LOL
__________________
Old 10-22-2009, 09:54 PM   #7
Nick.Simonds
Vehicle: 65 Coupe
Yeah I modeled my engine after yours
I think I just copied your parts list. Ha.
__________________
Old 10-23-2009, 10:50 AM   #8
69mach1377
1969 Ford Mustang
About 81-82, the 50 oz was used for the 5.0, but I'm not sure about the 5.8
I do know that I got the wrong one and had to have it fixed, so be careful.
__________________
69Mach1-SteetBoss377 Clevor,351W blk/stroker crank,10:1cr,351C-2V hds,2500 stall FMX,3.50:1 posi,rack&pinion/tilt,17x8 Mach1 Rims(2003),all MSD,Holley750,custom paint,Shelby drop,Cam Adv
http://photobucket.com/albums/v618/danaranda
69mach1377 is offline   Reply With Quote
351w, t5
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
