Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-26-2009, 08:36 PM   #1
67fastbak
Default home made coil over conversion build up
i have a 67 fastback and i want a better race style coilover conversion thats better then stock or mild aftermarket replacement parts and i want it to be on a budget. so i decided i would build my own since i already build a-arm off road race cars with 20 inch plus inches of travel i figured this wouldnt be to hard. it will be a conversion where the coil overs mount on the lower control arm not on the upper and the arms and struts will be made out of round chromolly tubing and use chomolly heim joints with screw in ball joints with sleeves. the coil overs will be QA1 single adjustable with 450 pound springs. i just wanted to let people see and know what your opinions on the project are.
in the pics are the parts that i have so far im still waiting on the heims and coilovers to come im but i m planning or starting to build the control arms tomorrow.
67fastbak is offline   Reply With Quote
Old 10-26-2009, 09:05 PM   #2
jasond393
1968 Ford Mustang
Vehicle: 68 Mustang
I know you are not done yet, but when you are would you make a list of what all is needed? Thanks
jasond393 is offline   Reply With Quote
Old 10-26-2009, 09:32 PM   #3
Nick.Simonds
Nick.Simonds's Avatar
Vehicle: 65 Coupe
Quote:
Originally Posted by 67fastbak View Post
450 pound springs
Maybe it is different with coil overs or something, but aren't 450 a little soft?
__________________
Nick.Simonds is offline   Reply With Quote
Old 10-26-2009, 09:35 PM   #4
cprstreetmachines
Not exactly, the leverage is applied different with this type of mounting point. The 450 is about a 650-700 lb spring in the stock location.
What ever you do, if you haven't bought them already skip the QA1's. They probably be leaking before you get them.
__________________
turbocharged 1967 349 stroker
1/8 mile 6.966 @ 99.704 Rich
1/8 mile 6.47@107.6 Dustin 1.43 best 60ft
cprstreetmachines is offline   Reply With Quote
Old 10-26-2009, 09:39 PM   #5
Nick.Simonds
Vehicle: 65 Coupe
Interesting, learn something new ever day.
__________________
Old 10-26-2009, 09:59 PM   #6
67fastbak
yes i alredy ordered the qa1s i was under the impression that they were alright since most of these types of conversions use them but if they leak ill rebuild them and use better seals.
and yes coil overs use lighter springs mostly due to the different angle that they are mounted at. there is a formula for finding the rate due to the angle that theyre mounted
Old 10-27-2009, 07:54 PM   #7
67fastbak
made some progress on the lower arms today. i just made a simple jig to make sure theyre straight and even
Old 10-27-2009, 07:57 PM   #8
67fastbak
and a few more pics
Old 10-27-2009, 10:28 PM   #9
Scott H.
Scott H.'s Avatar
Looks like you are having too much fun Should be very nice when you are done. Do you have a big block? Have you calculated the setback of the coil over?
I'm looking forward to watching your progress.
You are right, in that all the kits, like TCP, Ron Morris, etc, are very expensive for what they deliver. Nice to see another do-it-yourself-er.
While your at it, are you going to fab up your own Vario-centric camber kit?
Good luck!
__________________
Scott Heath
http://www.cardomain.com/ride/2400202
Nothing groovier than the sound of a Supercharged, EFI 5.0 in a classic 'stang
Scott H. is offline   Reply With Quote
Old 10-27-2009, 10:39 PM   #10
67fastbak
no i have a smallblock. what do you mean by setback of the coilover? :/
and i am going to build my own camber kit but its not going to be adjustable it will be a square with a hole directly in the center and then ill use the hein joints to adjust the camber
67, camber, coil, coilover, conversion, fox, ii, kit, leaking, lower, mustang, overs, replacement, sound, variocentric
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
