1. TIN MAN.
2. better not be much. i would think around 100 if not less
__________________
Quote:
Originally Posted by THUMPIN455
If you take it to the third story and drop it just right it will clearance itself. Might not be pretty or functional when its done, but it would be in there.
Yup.. I've got the Tin Man Fabrication ones on our 67 and its makes a world of difference! Easy install and (depending on) the shop should be able to do it for 1 to 2 hours labor.
__________________ GT 351 - 67 Mustang / 68 Shelby Conversion (GT351.net)
Modified 351w, 4-Spd Toploader, Coil-Over Suspension, Power R&P, 4-Wheel Disks,
Currie 9" Rear with 3.25 & TrueTrac, Ron Francis Wiring, Vintage Air, Intermittent Wipers,
Sequential Tail Lights, Power Windows & Locks, Rear Window Defrost, Heated Seats.... Oct 2009 Mustang Forums ROTM Winner!
DAMN, you guys are fast. I usually use TCP. And it takes 3-4 hrs. They wrap around the frame rails up front and lay flat against inner frame rails in the rear. But take a good bit of massaging to fit the usually. Especially to lay flat on the back rails.
But the best is use the floor. TIME consuming, but worth the extra effort.
Just looked at the tinman...they only have two mounting points ?!
They get welded at various points in the front rails since they slide right up inside them a fair distance. I think I had 8 spot welds inside and outside the front rails as well as along the joint. Also they get a fair bit or solid welding on the rear rails. Once installed the difference in the cars stiffness was incredible.
