Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-31-2009, 04:19 PM   #1
setx69fastback
Vehicle: 1969 Mustang Fastback
Default license plate lamps - wiring
Last thing i need to do to pass inspection and get a 69 fastback registered and titled is to get the license plate lamps wired. I have some on order (http://www.designengineering.com/pro...sp?m=sp&pid=21) that won't need to be mounted, mainly because I can't even figure out where they would go, can't find any leads, etc. I've just got all ten pounds of the factory shop manual, but the wiring portion is as clear as mud where the license plate lamps are concerned. I know i can just tap into the running lights / blinkers, but my concern there is that it's one bulb for both the blinkers and the running lights in the back, I'd rather not have one bulb or the other blinking with the blinkers. is there a better place to tie in, or am i just missing something entirely?
setx69fastback is offline   Reply With Quote
Old 10-31-2009, 04:28 PM   #2
Stepman
Vehicle: 69 coupe
Mine has a black wire under the fuel filler that has a female "bullet" connector at the end. It is connected to the wire for the light. As far as I can tell, it's tapped into the left tail light. (from the factory)
Stepman is offline   Reply With Quote
Old 11-01-2009, 06:26 AM   #3
kalli
Vehicle: 1964, Ford, Mustang
no i dea where it's tapped, but obviously needs to run with the tail lights. here's a diagram
http://www.midlife66.com/wiring/wiring.html
__________________
1964 1/2
302ci, Edelbrock RPM heads and cam, 650 speed demon, Long Tube headers and Flowmaster 40s
Quick Performance Racing 9" rear, Moser axles, 3.5:1 trac-loc from FRPP and T5 transmission.
CSRP disc brakes front and FRPP discs back.
http://www.gascc.ie
kalli is offline   Reply With Quote
Old 11-01-2009, 12:01 PM   #4
oldrock
oldrock's Avatar
Vehicle: 1969, mustang, coupe
mine was exactly same as stepman described. You can see the wiring harness in the left side of trunk. You should also have the hole for the light mounting on top of lis plate. Remove the plate and you should see how it mounts. PRetty straight forward.
oldrock is offline   Reply With Quote
Old 11-02-2009, 08:47 AM   #5
69FB
Vehicle: 1969 Fastback
Hmm I like the option that you found for the license plate light setx. I cannot remember if mine worked or not but since I'm having the whole car currently rewired I need to check this.
Good luck on the inspection. I know from experience sometimes they can be picky on their inspections in Texas.
69FB is offline   Reply With Quote
Old 11-02-2009, 09:52 AM   #6
2+2GT
Vehicle: 66 Mustang 2+2GT
I know these are not 69, but the setup was identical.
If you look below and to the right of the gas cap, you'll see the hole for the wire:
Don't forget the rubber flap, shown here. all 67-70 had a rubber flap, while the 71-72 had a plastic flap:
2+2GT is offline   Reply With Quote
Old 11-02-2009, 10:19 AM   #7
kalli
2+2, you involved with Glazier ?
__________________
1964 1/2
http://www.gascc.ie
lamps, license, lights, plate, wiring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
