Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-01-2009, 12:24 AM   #1
means42
Vehicle: 1965 Ford Mustang Coupe
Default Rack and Pinion vs. Stock steering? Recommendations
I have a 65 mustang coupe that I have stripped down/blasted, putting on new panels, doors, fenders, hood, etc.
I am planning on putting in a 5.0 with AOD set up. I want pwr steering, pwr brakes, pwr windows, pwr locks, key less entry, etc. Yea I know
I currently have in boxes in my garage the grab a track pwr steering set up and suspension with GT springs, 4 1/2 mid eye for rear, upgraded to edelbrock shocks, etc. I also have 09 Mustang GT disc brakes front and back with Mustang Steve's conversion set up to fit this car and stock steering suspension.... that being said.....
Since the car is stripped down.... should I go for a rack an pinion set up versus a stock steering? I have heard the rack and pinion set ups do NOT have the turn radius the stock does? Is this true?
Also, I really wouldn't want to spend over 2,500 for the set up and then I guess I could return all my new stuff. I am really struggling with this and want to make the right decision... please help!!!!!!
means42 is offline   Reply With Quote
Old 11-01-2009, 11:33 AM   #2
MonsterBilly
1966 Ford Mustang
Vehicle: 66 coupe
im not sure about R&P but my stock set up functions well but the radius is horrible. my 06 dodge 2500 with 35" tires turns better. there is however a bumpsteer kit that is supposed to improve the stock turning radius by 20% also.
anything to improve the radius will be a plus. I could imagine it being worse
__________________
66 coupe, 289, T5, Stealth Intake, Holley 670 Street Avenger, Centerforce Clutch, Headman Headers, Pypes Exhaust, Lunati Cam
MonsterBilly is offline   Reply With Quote
Old 11-01-2009, 02:41 PM   #3
jcoby
Vehicle: 1967, Ford, Mustang
I've been researching this over the past few months, and have come up with some stuff that might help:
- The rack has about 1" of total travel less than the steering box. That will remove 1/2" from each direction and increase the turning radius accordingly. I don't know exactly how much, but I'm guessing that's about a 1/2 turn of the wheel's worth.
- The is a bumpsteer kit that relocates the arm down and forward about 1/2", restoring the turning radius.
- Mosts of the aftermarket systems are based on a GM J-car rack (sunfire, celebrity, etc). Some are modified for the Mustang application, but are still based on a J-car. I've heard of some people using one out of a Taurus, but the same caveats apply.
- If you are one of the unlucky ones without any sort of joint on the steering box, you will have to either cut the steering shaft or buy a new steering column. You're pretty much committed if you cut your steering shaft.
- The Mustang has problems with U-joint angles when retrofitting a rack and with clearing headers.
With all that said, I'm probably going to at least try to fab up a rack from a J-car. My manual box is shot, one of the races on the steering shaft is destroyed, and I don't want to spend $500 on another one (I have the long-shaft version). I can get a rack for about $40 plus a couple hours of my time. I have the serpentine system from a '92 mustang that includes a power steering pump that I'll use.
jcoby is offline   Reply With Quote
Old 11-01-2009, 04:57 PM   #4
tx65coupe
tx65coupe's Avatar
Personally, I would keep the stock front suspension and steering and just rebuilt and upgrade it.
tx65coupe is offline   Reply With Quote
Old 11-01-2009, 05:11 PM   #5
2+2GT
Vehicle: 66 Mustang 2+2GT
Well set up OE PS with the proper 4-turn gearbox actually works pretty well. It's reputation for problems comes from people using generic hoses, missing clamps and brackets, etc., basically crappy maintenance.
2+2GT is online now   Reply With Quote
Old 11-01-2009, 10:01 PM   #6
Scott H.
Scott H.'s Avatar
The only R&P kit that I am aware of which keeps the stock turning radius is the Uni-Steer Power Rack and Pinion kit. They modify the barrel and stops of a J-car rack in order to get a full 7" of rack travel.
Having very carefully studied this whole thing, and gone through the process, it is the only kit I would use (unfortunately it wasn't available when I made the decision, so I used Randall's Rack, which was the best available for the money at the time).
The Pro Motorsports bump steer kit, requires lowering of the car to match the kit. It is not adjustable, and with a R&P, requires the car to be lowered more than is optimal for best handling.
Otherwise, I'd stick with a complete rebuild of the stock system, done by a professional. There was a guy on this site who was well known for quality rebuilds (sorry I can't remember who he is).
Another option is to completely change the entire front suspension (kind of a "throw the baby out with the bathwater" aproach). Check with the guys at CPR, they've done a few installs of the AJE system, which is pretty close to your budget limit. I have no personal experience with this system, and have not read any good or bad long term, or track use reviews.
Good luck!
__________________
Scott Heath
http://www.cardomain.com/ride/2400202
Nothing groovier than the sound of a Supercharged, EFI 5.0 in a classic 'stang
Scott H. is offline   Reply With Quote
Old 11-02-2009, 10:15 AM   #7
Deviousfred
1965 Ford Mustang
My Garage
Deviousfred's Avatar
Vehicle: 65 Mustang Coupe
I say screw the PS. Find yourself a power steering box (which you may already have) that has 16:1 3 3/4 turn (HCC-AW.) Send it off to stangerssite.com to rebuild. Then get yourself a Shelby quick steer kit with a roller idler bearing, and Pro-Motorsports bumpsteer kit. IMO, this will blow most racks out of the water and for a fraction of the price.
http://stangerssite.com/
http://www.cobranda.com/qukit.html
http://www.mustangsplus.com/xcart/pr...7&cat=0&page=1
http://www.mustangsplus.com/xcart/pr...at=3205&page=1
you may find this kit cheaper if you shop around.
I suggest the Pro-Motorsports kit because it also quickens steering by moving the tie rods an inch forward from the stock location.
EDIT: ditch all the PS stuff and get yourself a manual drag link.
http://www.mustangsplus.com/xcart/pr...at=2091&page=1
__________________
Fred
65 Mustang Coupe
Blah Blah Blah
Charlene
Deviousfred is offline   Reply With Quote
box, car, make, motorsports, mustang, part, pinion, pro, quick, rack, randalls, rod, shelby, steer, steering, tie
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
