No, no bad news.
My buddy never put the V8 into it. It just came with it. He took the I6 out of it a couple years ago when he was stripping it down. I have been looking into all what I need to do the V8 conversion and I plan on trying to get it up as close to Shelby specs as best I can.
It should get interesting.
Lynn
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
'99 GT automatic
CDC Shaker scoop, K&N Filter
MAC cat back
Max Speed 1 ½” Lowering springs
KYB GR2 shocks and struts
Cobra front brakes
I'll be getting a export brace for the car, do I take and cut off the old brace ends that are welded to the tower, or do I bolt it over the top of them with new one?
Lynn
__________________
'99 GT automatic
MAC cat back
Cobra front brakes
cutting off the old ones (i just used a pneumatic hacksaw) will be a cleaner job. if you don't cut them off you'll be looking at those weird stumps for the rest of your life. there's a good few who left the stubs on but i don't like the looks of it (personal opinion).
check this one out. that's mine which is a half assed job:
__________________
1964 1/2
302ci, Edelbrock RPM heads and cam, 650 speed demon, Long Tube headers and Flowmaster 40s
Quick Performance Racing 9" rear, Moser axles, 3.5:1 trac-loc from FRPP and T5 transmission.
CSRP disc brakes front and FRPP discs back. http://www.gascc.ie
I left the brackets on my shock towers when I installed my export brace. Like kalli said, it's a personal preference. The export brace will clear either way. I agree it looks cleaner with them removed. I'm just funny about cutting and drilling on my car if I don't have to. I don't know why, it's not like I'm ever going to reinstall the stock braces. One thing to note, leaving the brackets on leaves a nice sharp corner to snag your hand on when installing valve covers or spark plugs. Ask me how I know.
I've seen both ways on the old export brace. Some folks cut them off and I've seen others leave them where they are.
Honestly though...I cut mine off...it looked pretty bad to me to leave them and you will notice them there.
As far as how to get the undercoat off...heat gun and a puddy knife works but if I already had my car torn down that much I'd probably just send it out to be blasted.
I'm trying to get the steering linkage off the steering box. I have gotten the nut off, and I have beaten the side of the arm like I did the Tie rod arms making them pop apart trying to get these to pop apart the same way.
They will be replaced, so if the ends get damage it isn't a big deal, so can you use a pickle fork to separate it? Or should I keep trying to hit it and see if it will pop off?
Thanks,
Lynn
__________________
'99 GT automatic
MAC cat back
Cobra front brakes
Thanks,
Lynn
A pickle fork and a big hammer should pop them right apart. Project looks like a good one, good luck!
