Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-03-2009, 12:01 AM   #11
hiboostwoody
hiboostwoody's Avatar
Vehicle: 1967 Fastback
DUDE! Get a spring compressor before you kill yourself! Coil springs that come un****ed at the wrong time can be deadly.
__________________
Absolute rule number one: If it has tires or tits, your going to have trouble with it.
hiboostwoody is offline   Reply With Quote
Old 11-03-2009, 12:12 AM   #12
67t5ponycoupe
1967 Ford Mustang
Vehicle: 1967 GT Coupe
He can't use a sprnig compressor with the shock still in the spring. Take a long pry bar and go under the uppercontrol arm, by the upper ball joint. The end of the prybar will need to be on top of the frame where the upper control arm bolts on. You will be able to get enough leverage to lift the control arm up and slide a piece of wood between the upper control arm and the frame. When you let off the pry bar the the spring should be unloaded enough to upbolt the shock.
67t5ponycoupe is offline   Reply With Quote
Old 11-03-2009, 12:18 AM   #13
hiboostwoody
Quote:
Yes he can. http://www.etoolcart.com/macphersons...ratd-3054.aspx It says McPherson strut spring compressor but they work just as well for these coil springs as they are designed to be used on the outside of the spring. I have used them for this many times.
__________________
Old 11-03-2009, 12:20 AM   #14
rmodel65
2nd Amendment Gear Member
rmodel65's Avatar
Vehicle: 1965, ford, mustang fastback
Send a message via AIM to rmodel65 Send a message via MSN to rmodel65 Send a message via Yahoo to rmodel65
orrrrr how about just cutting the spring in half easy done.....
__________________
Founder Rmodel's Mustang Militia
“If ye love wealth better than liberty, the tranquillity of servitude than the animating contest of freedom, — go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that ye were our countrymen!”
~Samuel Adams
rmodel65 is online now   Reply With Quote
Old 11-03-2009, 02:09 AM   #15
jonward786
jonward786's Avatar
Vehicle: 1968 Coupe
this thread is confusing
__________________
jonward786 is offline   Reply With Quote
Old 11-03-2009, 02:13 AM   #16
nba1341
Vehicle: 1965 mustang fastback
lmao at kermit
__________________
1965 mustang fastback 302
nba1341 is offline   Reply With Quote
Old 11-03-2009, 02:35 AM   #17
EZFEED
EZFEED's Avatar
Vehicle: 1967 Mustang convertible
Yes he can 67t5ponycoupe.....there are external compressors available.
Two required per spring and they are quite safe...this yanking it out with a chain is begging for a concussion.
Rmodel is right too, if he has a torch he can slice it but only if the front is jacked up and the control arms are all the way down so there is little pressure built up in the spring.
__________________
1967 convt "under construction"
http://img.photobucket.com/albums/v4...0cancer/p1.jpg
1923 Model T Ford roadser "almost done!"
http://img.photobucket.com/albums/v4...Picture146.jpg
1969 M35A2
http://img.photobucket.com/albums/v4...s/EZM35A21.jpg
1976 PLDvK 53/59 (one of three in the U.S.)
http://img.photobucket.com/albums/v4...s/EZPLDVK1.jpg
"Collector of old machines, tractors, and all sorts of other crap"
EZFEED is offline   Reply With Quote
Old 11-03-2009, 02:42 AM   #18
MetalEd
Vehicle: 1964 170 I6 Coupe
Quote:
Originally Posted by LynnBob Mustang View Post
What happened when you cut them, did the coil parts suddenly drop together when it suddenly decompressed?
Have a buddy with a pickup truck? Borrow a couple of ratcheting tie-down straps.
They may not be the safest way, but they should compress your springs and would be safer than the cut-n-run method. Probably as safe as the chain.. If you don't want to invest in a spring compressor for one time use, then you might want to invest $10 for some straps... can use them to pull out a bumper or dent or even hold on a transmission<grin>
http://mustangforums.com/forum/6475750-post10.html
(thanks adrewmp6)
__________________
Ed - 64 Coupe I6 170ci
20 years late getting my dream car, but my son driving it to his high school is just as wonderful!
MetalEd is offline   Reply With Quote
Old 11-03-2009, 05:39 AM   #19
65rangoon
is the body of the shock pressing against the top of the fender apron?
If you are jacking it up the spring should compress unless something is binding and preventing it from happening.
65rangoon is offline   Reply With Quote
Old 11-03-2009, 07:11 AM   #20
LynnBob Mustang
LynnBob Mustang's Avatar
Vehicle: 1999 GT
I got the shocks off this morning.
I borrowed an external spring compressor as that is all I could find locally without going 35-40 miles to get to Auto zone.
I first thought of compressing the spring, but the thing wouldn't fit in between the coils with the hock in place to get it to work, so that option was out.
Lynn
Anyway.... I was able to get the other shock bolt back on and re tighten it down bring the back bolt close enough to get a socket on it.
Now I should be able to get the springs out this afternoon with the compressor.
Lynn
__________________
'99 GT automatic
CDC Shaker scoop, K&N Filter
MAC cat back
Max Speed 1 ˝” Lowering springs
KYB GR2 shocks and struts
Cobra front brakes
'65 Mustang coupe in progress
LynnBob Mustang is offline   Reply With Quote
1966, 66, coil, compressor, front, instructions, maxspeed, mustang, performance, rear, removal, remove, replacing, shocks, spring, springs, tech
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
