Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-02-2009, 09:48 PM   #1
LynnBob Mustang
LynnBob Mustang's Avatar
Vehicle: 1999 GT
Default Coil spring removal (in deep doo doo)
Well, I was trying to get my coil springs off and I ran into a big problem now.
First and foremost my car has no engine or tyranny in the car so there is no weight up front what so ever.
Here is what happened.
I removed the out shock towers, pain the butt, but no biggie.
I had my wheels off, jack stands under the frame rails, and I had a jack under the LCA supporting it.
I took and went to remove the lower shock bolts by first removing the one towards me first. I then went to remove the back one and it is a pain in the butt to get to.
I almost had the bolt all the way off when the tension of the coil suddenly pushed the shock up taking up the 1/2"-3/4" space of the shock bolt and making a loud bang by the partially decompressing the spring and moving both control arms down, scaring the crap out of me in the process.
Now is the problem, I still gotta get that last bolt off the lower shock. Since there is no weight to give the suspension any resistance I can't take and jack the LCA up so it will recompress the spring so I can get that last bolt off. When I jack up the LCA the whole damn car lifts up and the control arms won't move.
Now what???
How do I get the damn spring off now?
I think alot of the tension is off the spring now when comperd to the other, but I don't trust it so I chained it to the tower.
I'm thinking I may be able to keep the jack under LCA and remove the rear bolt of the LCA and drop it, thus re leaving the pressure off the whole dang thing.
Any ideas? I need help..
Lynn
__________________
'99 GT automatic
CDC Shaker scoop, K&N Filter
MAC cat back
Max Speed 1 ˝” Lowering springs
KYB GR2 shocks and struts
Cobra front brakes
'65 Mustang coupe in progress
LynnBob Mustang is offline   Reply With Quote
Old 11-02-2009, 09:55 PM   #2
rmodel65
2nd Amendment Gear Member
rmodel65's Avatar
Vehicle: 1965, ford, mustang fastback
Send a message via AIM to rmodel65 Send a message via MSN to rmodel65 Send a message via Yahoo to rmodel65
are you gonna replace the springs?? do you have a cutting torch? id cut them off:P
i cut mine of with the plasma cutter, if you leave the shock in place and cut it up its not gonna fly out of there
__________________
Founder Rmodel's Mustang Militia
“If ye love wealth better than liberty, the tranquillity of servitude than the animating contest of freedom, — go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that ye were our countrymen!”
~Samuel Adams
rmodel65 is online now   Reply With Quote
Old 11-02-2009, 10:01 PM   #3
2+2GT
Vehicle: 66 Mustang 2+2GT
Get some fat friends to sit on the rad support, and place an oak board between the upper arm and the frame.
2+2GT is offline   Reply With Quote
Old 11-02-2009, 10:17 PM   #4
LynnBob Mustang
Vehicle: 1999 GT
What would happen if I did unbolt the rear LCA?
Will that all the everything to drop and releave the pressure of the spring?
__________________
'99 GT automatic
MAC cat back
Cobra front brakes
Old 11-02-2009, 10:19 PM   #5
LynnBob Mustang
Vehicle: 1999 GT
No, I'm not saving them.
What happened when you cut them, did the coil parts suddenly drop together when it suddenly decompressed?
Lynn
__________________
'99 GT automatic
MAC cat back
Cobra front brakes
Old 11-02-2009, 10:21 PM   #6
rmodel65
rmodel65's Avatar
it expanded and took all the pressure off of them then i unbolted the shocks....
__________________
~Samuel Adams
Old 11-02-2009, 10:24 PM   #7
dodgestang
Vehicle: 1965, Mustang, Fastback
No it wouldn't. However since you still have the shocks in place, bolt the caps back on, un-bolt the upper arm, get your longest crow bar hook it into the upper arm and yank (and run). This will get the upper arm out and relieve the pressure. The shock will keep the spring from killing you (if you are lucky like I was when I took out my old uppers and springs without a compressor). The silver lining is if you are putting in drop springs like everyone seems to like you can put them in without a spring compressor.
__________________
Nick
65FB 408c AOD D.T.
11.521 at 118.85 (Best ET to date 11.45 at 118.85)
http://www.youtube.com/watch?v=c60rI5RWnJw
dodgestang is offline   Reply With Quote
Old 11-02-2009, 10:34 PM   #8
noroof66
Vehicle: 1966 Ford Mustang
Either cut, or get a spring compressor.
__________________
1966 289
noroof66 is offline   Reply With Quote
Old 11-02-2009, 11:46 PM   #9
EZFEED
EZFEED's Avatar
Vehicle: 1967 Mustang convertible
Why didn't you use a spring compressor for this?....free from AutoZone....?????
__________________
1967 convt "under construction"
http://img.photobucket.com/albums/v4...0cancer/p1.jpg
1923 Model T Ford roadser "almost done!"
http://img.photobucket.com/albums/v4...Picture146.jpg
1969 M35A2
http://img.photobucket.com/albums/v4...s/EZM35A21.jpg
1976 PLDvK 53/59 (one of three in the U.S.)
http://img.photobucket.com/albums/v4...s/EZPLDVK1.jpg
"Collector of old machines, tractors, and all sorts of other crap"
EZFEED is offline   Reply With Quote
Old 11-02-2009, 11:59 PM   #10
4reboy
4reboy's Avatar
Vehicle: 1969 Mach1
I think I understand your problem, i would just use the spring compresser, it should lift up the spring and you can then get to the bolt and hopefully still be able to pull the shock out.
__________________
1969 Winter Blue Mach 1 M-code - mine
1969 Mach 1 428 R-code - dad's new project
1971 Mach 1 H-code - dad's (for sale)
Classic ROTM 2009 winner thanks everybody
4reboy is offline   Reply With Quote
1966, 66, coil, compressor, front, instructions, maxspeed, mustang, performance, rear, removal, remove, replacing, shocks, spring, springs, tech
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
