Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-03-2009, 10:34 PM   #1
tag817
Vehicle: 2000 ford mustang
Default 65 rear end
I just bought a 65' coupe. it has a 90's model 5.0 and they also put a 5 speed in it. it's pretty strong but i think it has the original rear end. Is there an easy way to tell by looking?
tag817 is offline   Reply With Quote
Old 11-03-2009, 10:44 PM   #2
capri man
capri man's Avatar
Vehicle: 73 mach 1, 81 capri
if the chunk will come out from the front it is probably the original 8 inch. if it has a plate on the rear that exposes the gears, it is probably the newer 8.8 inch rear end.
__________________
73 Mach 1 riding around, drinking car
81 capri drag car
racing is real, everything else is just a game!!
capri man is offline   Reply With Quote
Old 11-04-2009, 05:09 AM   #3
tx65coupe
tx65coupe's Avatar
Vehicle: 1965 Ford Mustang
Like he just said, look and see if the rear end has a removable cover on the back or not. If it does it is probably a late model 8.8. If it doesn't it is most likely an 8 inch, but could also be a 9 inch.
If you have a tach, What RPM are you turning on the highway in 5th doing about 70?
I would recommend 3.50-3.70 gears.
tx65coupe is offline   Reply With Quote
Old 11-04-2009, 07:11 AM   #4
2+2GT
Vehicle: 66 Mustang 2+2GT
If the diff is a removable piece, with studs and nuts around the front, it's a 8" or 9". You can use a socket and 6" extension on the nut of the 8", but the 2 lower-right nuts on the 9" would be blocked by the pinion housing.
The 8" will be fine, if you are not racing the car. The 8&9 were identical in design, the 9" was just 1" larger and beefier. Currie has a 4-pinion Traction-Loc diff if you need to convert to limited slip, this is stronger than a lot of stock 9" diffs.
2+2GT is online now   Reply With Quote
Old 11-04-2009, 03:15 PM   #5
tag817
it doesn't have the bolt on removable plate, so it is probably the original (it looks 44 years old too) what are the lowest gears i can put in the original 8 inch? will 3:70's fit?
Old 11-05-2009, 08:56 PM   #6
tx65coupe
tx65coupe's Avatar
You should be able to run 3.70 gears in the 8 inch. I would upgrade to traction lock and replace all the bearings and seals while its opened up.
88, chunk, end, ford, fozwaa, rear
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
