Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-04-2009, 05:17 PM   #1
colt1567
Vehicle: 1969 Ford Mustang Convertible
Red face anti stall dashpot and idle adjustment
hi, i have a 69 mustang 302 a/t and it dies when i put it into gear. how do i adjust my anti stall dashpot and idle speed correctly?
__________________
CDM
colt1567 is offline   Reply With Quote
Old 11-04-2009, 07:03 PM   #2
groho
is your dashpot vacuum actuated?
groho is offline   Reply With Quote
Old 11-04-2009, 07:10 PM   #3
groho
basically, set all settings, air/fuel, idle, fast idle, as normal. Your running an automatic, your idle is probably around 700-800 RPM. Once set, then adjust the dashpot to the appropriate clearance from the linkage, probably 1/8 -1/16" as indicated in manual. If you have a vacuum operated dashpot, remove/block the vacuum line while setting the idle.
Old 11-05-2009, 05:14 PM   #4
colt1567
ok. hey, is there anywhere i can find the specs on the air fuel mixture and the other settings specs?
__________________
CDM
anti, anti stall dashpot, dashpot, forum, mustang, offidle, stall
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
