Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-05-2009, 12:31 AM   #1
Silverblade
Vehicle: 67 Coupe
Default Wiring horn to aux swtich?
My car came with an aftermarket steering wheel and no horn, which I need to pass inspection. It also conveniently has an aux switch for fog lights that dont work. I am trying to wire the horn up to the switch but either way I try it it isnt working.
Battery -> Horn Positive with Horn Negative -> Switch -> Ground results in the horn making a weak noise of it grounding out less "HONK" more "tink.." and that is all it gets. If i play with the ground and move it around and let it spark it just does the same thing, a faint "tink" with every spark.
Power Source -> Switch -> Horn Positive with Horn negative grounded does the same thing.
I was hoping to go for inspection this saturday, any input greatly appreciated!
2 powers? 2 grounds? I was told an airhorn in the glovebox wont suffice..
__________________
Quote:
Originally Posted by FuzzyDiceRule View Post
Then, as per the blantantly awesome part, we painted it lime green
Quote:
Originally Posted by TorinoCobra070 View Post
eskimos - frozen vag FTL
Silverblade is offline   Reply With Quote
Old 11-05-2009, 10:10 AM   #2
Stepman
Vehicle: 69 coupe
Sounds like you have a dead horn. I would hook it up through a relay, myself.
First, ground the horn.
Next, run a wire from pos of horn to switched side of a relay.
Then run 2 power wires to the relay (or 1 wire can be split into 2 at the relay.) You need 1 for the switched side to send power to horn and 1 to power the relay. (control side)
Last, run a ground wire from the relay to your switch, and ground the other side of the switch.
Grounding in this way keeps the power off the switch and sends it remotely to the horn. This is the same set up as the "light relays" that everyone is doing. Also, I would use a push button "spring" switch instead of a "toggle".
Stepman is offline   Reply With Quote
Old 11-05-2009, 10:48 AM   #3
Adrenolin
1967 Ford Mustang
Adrenolin's Avatar
Vehicle: 67 Ford Mustang
Find out if the horn itself is working first. I find test wires work great for this type of thing. clip to wires directly to the - & + horn contacts. Hold the - wire to the - battery post and then hold the + to the + battery post. Only need to hold it there for a second or 2 as the horn should either work or not. No need to 'play' with the wires or let them spark.
Using an actual switch to test isn't always a good idea, like in this situation. It could be a bad switch, wiring connections would be bad, wires crossed while in a rush for that quick test, etc, etc. Test the horn or whatever first then add a switch, relay, etc. Start with the basics and then add to it.
__________________
GT 351 - 67 Mustang / 68 Shelby Conversion (GT351.net)
Modified 351w, 4-Spd Toploader, Coil-Over Suspension, Power R&P, 4-Wheel Disks,
Currie 9" Rear with 3.25 & TrueTrac, Ron Francis Wiring, Vintage Air, Intermittent Wipers,
Sequential Tail Lights, Power Windows & Locks, Rear Window Defrost, Heated Seats....
Oct 2009 Mustang Forums ROTM Winner!
Adrenolin is offline   Reply With Quote
Old 11-05-2009, 01:00 PM   #4
2+2GT
Vehicle: 66 Mustang 2+2GT
Have you tried the horn with the engine running? The battery is 12V, while the car runs on 14V. I have seen this make a weak horn work properly.
2+2GT is offline   Reply With Quote
Old 11-05-2009, 03:28 PM   #5
Silverblade
Vehicle: 67 Coupe
the horn was bolted to the car and grounded and when i first put power to it before adding the switch it would work properly. but then we couldnt replicate that later on as it would just spark again
we also ran out and grabbed a push button for the horn to see if it was the switch and the same thing happened, when i pushed the button it just made the faint tink noise.
__________________
01, 67, aftermarket, aux, car, horn, inpection, move, mustang, nj, switch, wire
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
