Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-08-2009, 02:28 PM   #11
THUMPIN455
THUMPIN455's Avatar
Vehicle: Too many to list, 30+
Quote:
Originally Posted by Starfury View Post
I agree completely with Thumpin. Get pushrods separate after you've measured for proper length.
Reading minds again bro? I agree with Ez too, been thinking about trying a set of these heads on a Ford and also a 400sbc that is going in a truck. From what I have seen is they are a little better than a stock replacement head, a little more power in the chevy over Vortec heads, but that means squat with a Ford. Might put a set on the F150 4x4 I use as a winter truck, it needs more power and a 347 on the cheap would be nice in that thing.
You really need the proper pushrod length, and for some reason Fords are very sensitive in that area even with adjustable valvetrains. There is no way to know where your length ends up due to variances in the blocks deck height, cam height, head gaskets, and the heads themselves. You have to put the thing together then use a pushrod length checker to find out what length pushrods you need. A one size fits all kit will often end up with extra parts you dont need because they wont fit. I have a bunch of bearings and a couple ring sets left over because the part wouldnt clean up at that size.
__________________
POD and Cougar progress pics:
71 Pit of Despair Mustang
67 Cougar
THUMPIN455 is offline   Reply With Quote
Old 11-08-2009, 03:26 PM   #12
Timetravelinn
Vehicle: 1965,Ford,Mustang
Thanks for all the input guys. I was shocked too about having to spend like a extra 500 bucks to install the heads. I was also under the impression that I would spend the money on the heads and maybe just have to spring for the gaskets if the heads were complete.
As for push rods everyones advise makes sense to get adjustable. Rockers I'm assuming the same thing you get what you pay for so I would want some quality rockers also.
But can I really just grab some gt40 heads off a explorer and gain an extra 40 horses. If thats the case I might be looking to go in that direction. I'm assuming the ones on the explorer are cast iron what's everyones thoughts on the aluminum ones they sell after market they're about the same as the e-street in price.
Afr heads would probably be my first choice but they're like 1400.
Timetravelinn is offline   Reply With Quote
Old 11-08-2009, 09:18 PM   #13
Starfury
Quote:
lol, oops. Been a stressful couple days, my mind isn't exactly where it should be.
Yes, TT, you can get good gains from a set of GT40 heads off a 95-96 Exploder. 97+ Explorers use GT40P heads which have altered plug angles. This puts the plugs smack into the header tubes on one side on classic applications. There are only two places I'm aware of that make headers for classic Mustangs with P heads, and both are very pricey (but high quality). Not that P heads aren't good heads, they're just a PITA in swap applications.
If you're interested, I can send you to someone who can get you some Trick Flows for fairly cheap. Same guy that got me mine
__________________
Tad H.
'67 Fastback
331 stroker
Starfury is offline   Reply With Quote
Old 11-09-2009, 09:01 AM   #14
kalli
Vehicle: 1964, Ford, Mustang
a nice surprise you'll get with aluminum heads is that the engine gets lighter. This made a _huge_ difference to my manual sterring. it got a lot lighter
__________________
1964 1/2
302ci, Edelbrock RPM heads and cam, 650 speed demon, Long Tube headers and Flowmaster 40s
Quick Performance Racing 9" rear, Moser axles, 3.5:1 trac-loc from FRPP and T5 transmission.
CSRP disc brakes front and FRPP discs back.
http://www.gascc.ie
kalli is offline   Reply With Quote
05, 302, 351, estreet, gt, hardened, heads, mustang, mustangs, pushrods, street, windsor
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
