Sponsored by:
Sponsored by:
Windows getting hung up?
Old 11-30-2006, 11:54 PM
95hooptey
95hooptey's Avatar
Default Windows getting hung up?
I had a an aftermarket top installed on my vert when I bought it............Its a great looking top except for the doors get hung up on the top wire that keeps the top tight. Basically when I close the door when the window is rolled up it hangs up on the top of the door seal. So the window does not fit inside the door jam and there is a space that you can see through.......
Its more bothersome than anything. I just have to unroll the window and roll it back up but geez...............
Any ideas??
95hooptey is offline
Old 12-01-2006, 12:23 AM
ebxgsxr
ebxgsxr's Avatar
Default RE: Windows getting hung up?
have you checked with the palce that installed the top? maybe a small adjustment is needed to fit correctly?
ebxgsxr is offline
Old 12-01-2006, 12:46 AM
ooticamitica
ooticamitica's Avatar
yea, definetely take it back because it shouldnt be doing that.
ooticamitica is offline
Old 12-01-2006, 11:18 AM
TwotoneVert
TwotoneVert's Avatar
Can you post a pic?
TwotoneVert is offline
Old 12-01-2006, 03:55 PM
vt89gtvert
vt89gtvert's Avatar
I concur with taking it back and rasinig hell. It shouldn't do that.
vt89gtvert is offline
Old 12-15-2006, 03:49 AM
petrock
petrock's Avatar
My girls '98 driver's side door does that same thing (passenger side is fine). The top of the window hits the top lining preventing it from seating in the weather stripping. If she rolls the window down and then back up, or pushes on the top of the window slightly after its hit, or slams the door real hard it fits fine. She doesn't know if its a stock top or not. It came with the car when she bought it 3 years ago. Its only been doing this for the past 6 months or so. I checked the door and it is lining up properly etc. How would I adjust the top to fit better? Thanks alot.
petrock is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
Explosive
10-02-2015 07:45 AM
DreadPirateRoberts
09-26-2015 02:11 PM
Quick Reply: Windows getting hung up?
