New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > General Tech > Convertible Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-17-2009, 10:20 AM   #11
01red
Vehicle: 2001 V6 Convertible
What I did for these leaks was stand the top straight up to gain easier access to the holes under the flaps. I glued a 4x4 inch piece of vinyl to each hole on the outside using lots of Goop. I then closed the top and glued annother 4x4 patch around the fold inside. I then clamped the repair and let it dry. (I didn't need the car for a week, so I am sure it cured while I was gone.)
So far no leaks since Memorial Day.
01red is offline   Reply With Quote
Old 08-05-2009, 02:40 PM   #12
clarehills
clarehills's Avatar
Vehicle: 2004 Ford Mustang Mach 1
Quote:
Originally Posted by DraKhen99 View Post
I probably lower and raise my top an average of 3-4 times per day (days when I drive the car, anyway), so I'm sure that's what caused it ... Mine appears to be in the bottom corners of the rear window though, since that's where the water looks like it's coming from.
I read through your directions for fixing the leaks, and I have a question: It seems like you have the top up when you apply the glue, but when you're letting it cure, do you have the top down? And do you do the inside and outside of the vinyl at the same time, or do you do one in one day, and the other the next day?
Thanks,
-John
Hey John, sorry for not replying sooner - I was out in the field
I have the top up when I am applying it and when it is curing. I did it this way because I wanted the glue to set when the top was in its most strectched condition. That way when I put it down the glue can relax/contract. If I had done it the other way around I suspect that the glue would have been too stretched and would give out.
In answer to your second question, I did the inside one day and the outside the next day - there should be no reason you cant do them the same day though...
The fix I made is still holding perfectly - I dumped a few buckets of water on it at the weekend and not a drop
Hopefully you get the same results...
clarehills is offline   Reply With Quote
Old 08-17-2009, 11:06 AM   #13
IRSmart
Vehicle: 2003 Ford Mustang GT Premium Convertible
this DEFINATELY needs to be a sticky, given that this is an all-too common problem. just went out to my car, and the two holes were right where you said they would be. i already purchased the tent repair kit talked about in another thread on here, but i haven't used it on the holes yet, so i'm not sure if this is the culprit or not. i normally just keep a towl in the back window of my car, and when it starts to stink, i trade it out with another one. we call it my car's tampon :lol:
__________________
4.30 gears, 15k miles $125 shipped SOLD!!
37 piece paint gun set, $80 shipped
2 trunk blackout kits (must be sold together, pm me for why) $25 shipped SOLD!!
Radio & shifter bezel, charcole, double din, $50 shipped
PM me for details
IRSmart is offline   Reply With Quote
Old 08-17-2009, 11:29 PM   #14
IRSmart
Quote:
So I had a total of 3 holes, right where you said they would be. The problem is, they were all the way at the bottom of the top, resting on the frame of the car, so I couldn't use the patch material on them. As I took the vinyl boot off below the top, I discovered a water canal behind it, meant if any water got in between the top and the car. Problem is that the vinyl boot covers this, and the water that leaks in just stays in the boot. So what I did was cut a hole out of the top of the boot to allow the water to get behind the boot, to the water canal, and out of the car. So the top still leaks, but the water is just directed right out of the car again. It's a much easier way to "fix" the leak, and the piece of cloth that is screwed to the back of the car and attached by a bungee cord hides the hole that I cut. If anyone is interested in what I did I can take pics on Thursday.
__________________
PM me for details
Old 09-07-2009, 03:59 PM   #15
scseg
scseg's Avatar
Vehicle: 2002 Mustang convert
Default Hole where window meets canvase
Any Ideas at the bottom of glass back window? Hole is in lower corners, so runs down window into the trunk, and gets amp wet.
scseg is offline   Reply With Quote
Old 09-09-2009, 10:14 AM   #16
clarehills
clarehills's Avatar
Quote:
Depending on the location of the holes I would suggest either the patch method or the 'channel' method - creating a safe path from the hole to the outside of the car, both methods are described in previous posts in this thread.
Have a read and let us know of those approaches won't for some reason, good luck!
Old 09-15-2009, 08:00 PM   #17
Greyhounder
Vehicle: 99 Mustang
That's a beautiful write-up! Thanks!
My 99 shows a little wear where those holes in the pictures are, but I don't think it's enough to let much water in. But my problem is at the bottom of the rear window. The vinyl roof material is glued to the glass itself (with some fake stitching for appearance), and that is coming loose. Before there was just about an inch on either side that wasn't tightly sealed, at the corners. Now one has opened, and more when I looked at it, so it's now 8" wide.
Does anyone know what kind of glue or sealant I can use to repair that? What will stick to the glass?
The initial problem is the vinyl boot behind the rear seat was filling up with water. It used to be a minor nuisance, but the other day a lot had collected, so it was pretty deep. We've had a lot of rain in DFW lately.
Greyhounder is offline   Reply With Quote
Old 09-21-2009, 11:14 PM   #18
clarehills
clarehills's Avatar
Dude, I would probably suggest some kind of flexible glue like the one earlier on in the post but if I was you I would go to ace hardware (or some such place where you live) and tell them what you need, they are a good bunch of lads and know their stuff:
- Flexible glue
- Long lasting glue
- Glue that adheres to glass/perspex and vinyl
Good luck!
clarehills
Old 09-29-2009, 10:32 PM   #19
Greyhounder
Vehicle: 99 Mustang
The 3M Weatherstripping stuff did the trick. I pulled the whole bottom part of the vinyl away from th glass and redid it all, and it's holding up great.
Thanks again!
Old 09-29-2009, 10:45 PM   #20
S197GT07
2007 Ford Mustang
S197GT07's Avatar
Vehicle: 2007 Ford Mustang GT
Glad it worked!
__________________
2007 Torch Red GT Ragtop
-Borla Singers
-Bama 93 Race Tune
S197GT07 is offline   Reply With Quote
00, 1999, 2004, 2005, convertible, fix, ford, gt, leak, leaks, mustang, repair, top, video, water
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
