Sponsored by:
Sponsored by:
Old 10-20-2015, 11:52 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Wheels and Tires
Print Wikipost
How to Fix a Leak in a 1999 - 2004 Mustang Vert
Old 04-12-2013, 08:30 AM
  #31
peterzinyou
peterzinyou's Avatar
Default Leaky top
Thank you to everyone on this post. 04 GT with same problem, will get to it this weekend and hopefully fix it. Again ty, these forums rock.
peterzinyou is offline
Old 04-12-2013, 09:58 PM
  #32
Special20
Special20's Avatar
Hi-- I have a 2003 Vert with the same holes in the same places. I went to my local dive shop and bought a couple of tubes of Stormesure. This is a flexible, waterproof adhesive. Divers use it on their dive suits and boots to repair holes. It is clear and self leveling. I located the holes and brushed it on with a small brush on the inside of the top. I also noticed a bunch of places where wear marks are present. I also brushed the Stormsure over the wear marks to make abrasion patches. It has held over 1 year now.-- Hope this helps.
Special20 is offline
Old 10-13-2013, 03:34 PM
  #33
Mustang_Don
Mustang_Don's Avatar
Glad I saw this thread. Mustang Forums is a great site! I went out to the garage after reading the posts here to look in the vinyl top well in my '03 convert. Car was parked outside yesterday when we had some heavy thunderstorms pass through, so I expected to find a little water there if the top had any leakage around the rear window. Sure enough, there was a little water there, a few thimble fulls at each side that I wiped dry with a chamois. Considering the intensity of the rain yesterday, I'm guessing the leaks are coming from pinhole-size holes near the lower rear corners of the rear window, so I don't consider it a really urgent issue but one for my to-do list. The car has been driven and parked in 2 or 3 heavy rainfalls since I got it in mid-August, but I assume that any rainwater that got in before yesterday has long since evaporated. I haven't checked the trunk yet, hope there's no water there...
Mustang_Don is offline
Old 04-19-2014, 03:58 PM
  #34
jrodriguez55
jrodriguez55's Avatar
I'm glad I am register to this Blog, good solutions that work. thank you every one.
jrodriguez55 is offline
Old 04-20-2014, 08:18 PM
  #35
ladybosanova
ladybosanova's Avatar
Default Rear Window leak on a convertable
I found out there are drains near the back window and if they get clogged then the water gets routed to inside the car including the trunk. I had my top replaced last year and learned this from the Tech.
ladybosanova is offline
Old 09-12-2014, 11:13 AM
  #36
Babik2242
Babik2242's Avatar
I have a 2001 convertible mustang and it seems to me when I look at the back window on the left and right side the fabric seems to be separating from the window and it leaks when it rains and I don't know what to use to fix it any ideas ? thank you !
Babik2242 is offline
Old 09-12-2014, 11:28 AM
  #37
atikovi
atikovi's Avatar
http://www.ebay.com/itm/TWO-tubes-DO...e=STRK:MESE:IT
I used it on the bottom of the window and it worked great, not sure of the sides.
atikovi is offline
Old 07-07-2015, 11:09 AM
  #38
Carolina Man
Carolina Man's Avatar
I am glad I found this now I can fix my leaks
Carolina Man is offline
Old 10-25-2015, 10:13 AM
  #39
bobbyo
bobbyo's Avatar
Thumbs up Convertible Leak Fix
I struggled with leaks created by the holes shown in the first post. Tried various fixes that didn't work well. Finally tried pumping the area both inside and out with Flex Shot clear as seen on TV. So far so good!
bobbyo is offline
Old 10-25-2015, 11:18 AM
  #40
Carolina Man
I used Gorilla Tape on mine as a temporary fix, my top has to be replaced it's in really bad shape.
Quick Reply: How to Fix a Leak in a 1999 - 2004 Mustang Vert
