Go Back   MustangForums.com > Ford Mustang Tech > General Tech > Convertible Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-27-2009, 10:15 AM   #1
tank59
Vehicle: 1995 Mustang GT
Default replacing a 95 convertible with an 04 top.
I am helping a friend out with his 1995 Convertible. He ordered a complete top (mechanisms and all) from a salvage yard. The top is off a 2004 mustang. He was able to remove and install the new top in just under a day. His issue is, the pins to latch the top to the frame are now about 3/4 to 1" shy of the holes. The tech at the salvage yard told him there is a bar that sometimes needs to be flipped if this issue occurs. We have been through every part of the mechanics but can't find a bar or joint that can be flipped or adjusted to give him the extra length. Any suggestions on the matter would be greatly appreciated.
tank59 is offline   Reply With Quote
Old 04-30-2009, 05:19 PM   #2
ryan1994mustang
Send a message via AIM to ryan1994mustang
i dont understand why it would be any shorter than the top that was on the car. the 94-04 all had the same top and im assuming the same assembly. are you sure everything got bolted in correctly?
__________________
1994 Mustang GT, just a few minor appearance mods, engine mostly stock (for now)
ryan1994mustang is offline   Reply With Quote
Old 05-01-2009, 09:38 AM   #3
tank59
Yes, everything was bolted in correctly, he has been through each part multiple times. His belief now is that the top needs to be slightly stretched, so he loosened the bolts and has the top closed and in the Sun to allow the fabric to stretch out. Then he will torque everything down. Hopefully this will work.
Old 05-07-2009, 02:24 PM   #4
redpony88
1983 Mercury Capri
My Garage
redpony88's Avatar
Vehicle: 95 Mustang GT
Send a message via AIM to redpony88 Send a message via Yahoo to redpony88
normally when you install a new top tightness is normal. you just pull a little harder to close it. i just did my top this past sunday. and just put a little weight on it and pull it closed
__________________
1983 Black GT- Sold
1988 Red GT-Sold
1995 Black GT - Cobra Front Brakes, 306, TFS 1 Cam, Eddy RPM Heads, Eddy RPM 2 Intake, 3.55 gears
1983 MERCURY CAPRI V6 "Uh-Oh Oreo"
redpony88 is offline   Reply With Quote
1995 convertible, mustang convertible swap
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
