Quote:
Originally Posted by BlackStallion98
The light bar came on my car when I bought it, but I dont know if the brake light is burned out or just not hooked up. Is there anyway to tell and/or replace or fix it? thanks
You should be able to probe the wires comming from the bracklight with a meter to see if they have power when the brakes are pressed. If you dont have a meter, you can get a cheap tester from any auto parts store ( a couple of dollars.) One end of the tester clips to ground, the other to a hot 12v source, and you can probe the wires for the light. Usually they turn green if there is 12v present, and red if ground is present. Or just replace the bulb for a few bucks and see if it works.
