Water should stay outside
Hi,
There *are* some exterior "body" drains, at least one on each rear quarter. I've not found them but I see their effect: when I run a low-flowing hose along the base of the top starting at the back of the rear side windows, water starts dripping from the forward part of the wheel wells. Pouring a cup of water along there has the same effect. So if water's not reaching those drains in your car, my guess is it's finding a hole first.
I think it's safe to say under normal circumstances you shouldn't be seeing any water on the floor. I've just found leaks in my 01 convertible too; in my case they're near the bottom corners where the rear window section meets the sides. Water collects in the vinyl "pocket" that holds the lowered top. I'm guessing if that vinyl section had rips in the corners, or if the water got high enough to reach the small velcro'd flaps on the back seat, it could easily end up in the trunk or on the floor.
Let me know what you find, and good luck.
