I put the top down yesterday. I went out. I came home and put it in the garage with the top down. I went to put it up this morning and it won't go up. I have power going out of both sides of the switch. I switched the relays and that didn't do anything. I'm guessing it's the motor. Any reassurance?
Thanks
Frank
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
try manually lifting the top, (you might need a friend) and then try it. mine does that sometimes and i start to manually lift it and when i get it about half way i push the button (going up) and it starts to work. i'm pretty sure its the motor but i haven't searched that hard, i usually wait til something completely breaks before i replace something.
__________________
fresh 306,Trickflow top end kit, T-5, 3:55's, Mac C/C plates, Eibach pro springs, Strange 10 ways, Pro 5.0, 24lb injectors, BBK 75mm tb, Pro M Maf/CAI, Walbro 190 lph, holley FPR, tubular k member, bbk shorty headers, o/r h pipe with no cats, flowmasters, 17x9 Cobra R, shaved doors, antenna and emblems, SVO hood, Saleen spoiler, no backseat and probably more
soon to come:
100 shot, rear suspension and new tires
i believe there should be 2 relays, one for up and one for down. you should hear a click when you hit the switch. try looking back there and figuring out which one it is. i havent messed with the fox verts but it should be similar.
__________________
1983 Black GT- Sold
1988 Red GT-Sold
1995 Black GT - Cobra Front Brakes, 306, TFS 1 Cam, Eddy RPM Heads, Eddy RPM 2 Intake, 3.55 gears
1983 MERCURY CAPRI V6 "Uh-Oh Oreo"
Thanks for the input guys. I figured out my problem. While I was disassembling the dash a few wires popped out of the connectors, dur to broken tabs holding them in. Well I had mixed up 2 wires. Once I switched them back it worked fine.
