i have an 89 and i want to go from power quarter windows to manual crank.
yes that would make it easier to break into but even if i leave the handle off and use it when i need to. how would i convert it to manual roll up 1/4 windows?
Also, when i hit the top switch i get the clicking in both directions up/down
but nothing happens. i replaced the top motor but it was from the junk yard.
i get the same action. are my hydraulic cylinders froze and not allowing top to move or motor to do what it should?
how can i check it?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
why do you want to go to manual windows? i think its not worth the time nor effort.
everynow and then i get the clicking noise, what i do is lean back and shake the motor while holding the button, (i have no back seat and its usually when its down) and it starts to work
so it makes me think that i have a bad ground or air in the system. did you install the pump? did you bleed it?
__________________
fresh 306,Trickflow top end kit, T-5, 3:55's, Mac C/C plates, Eibach pro springs, Strange 10 ways, Pro 5.0, 24lb injectors, BBK 75mm tb, Pro M Maf/CAI, Walbro 190 lph, holley FPR, tubular k member, bbk shorty headers, o/r h pipe with no cats, flowmasters, 17x9 Cobra R, shaved doors, antenna and emblems, SVO hood, Saleen spoiler, no backseat and probably more
soon to come:
100 shot, rear suspension and new tires
yes i put the new/used pump in. i didnt bleed it. what oil should i use?
should i be able to push or pull the rod in the hydraulic cylinder by hand.. cause i cant.
the windows i just thought it would be cheaper to make manual than to buy new motors.
i dont put my top down because the 1/4 windows stay up and i dont like how that looks.
the windows i just thought it would be cheaper to make manual than to buy new motors. i dont put my top down because the 1/4 windows stay up and i dont like how that looks.
its like a 7 seven dollar fix at autozone. usually
__________________
soon to come:
I changed my 1/4 windows from power to manual on my 88 'vert. You need the whole crank assembly for manual. I changed for simplicity. Something less to go wrong.
My assemblies came out of an '87. They bolted right in the factory holes. If you look in a catalog you can get an idea of what years you can use. Somebody must sell them. I haven't looked myself but will if I get a chance. I loaned my catalogs to a friend who is building now.
