Go Back   MustangForums.com > Ford Mustang Tech > General Tech > Convertible Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-07-2009, 08:25 PM   #1
charlie32
Vehicle: 2007 Mustang Convert.
Send a message via AIM to charlie32
Default O7 Window Problem
Have a 2007 Convert. When I toggle the Up switch on the Pass. window it goes full up then lowers to the 1/2 way position. ??? If I can catch it just as it hit the full up position and I hit the switch again--it will stay up.
A Pain------Any of you encounter the same prob..
charlie32 is offline   Reply With Quote
Old 11-07-2009, 09:14 PM   #2
ryan1994mustang
Send a message via AIM to ryan1994mustang
do the 07's have the auto up on both driver and passenger windows? my moms altima (i know its not a mustang) had a similar problem. if you used the auto up then it would go all the way up and then come back down like 5-6 inches. if you just used the regular up then you could close it properly. try this and see if it works. i know its not a permanent fix, but it should help you out for the time being. as far as fixing it goes, it seems like the window might be going up too high and hitting a stop and making it go back down a few inches. make sure the window is adjusted properly. also, you might want to check in the s197 tech section, as the convertible section doesnt get too much traffic.
__________________
1994 Mustang GT, just a few minor appearance mods, engine mostly stock (for now)
ryan1994mustang is offline   Reply With Quote
Old 11-13-2009, 11:57 PM   #3
dsnaf2u
Vehicle: `07 Mustang Vista vert.
On my `07 vert the rear windows must be full up before I can close the pass. front. If the rear is even slightly open the front does back down 1/2 way. If not that, check for contact at the top.
dsnaf2u is offline   Reply With Quote
Old 11-14-2009, 05:52 PM   #4
JohnTN
2006 Ford Mustang
Vehicle: 2006 Mustang GT Convertible
There is a TSB that might apply to your problem. Check the 4.0 V6 Forum for the thread "Window Problem". 157db provided a link to the TSB which I tried today and it fixed my bounce-back problem on the drivers side that started after a low battery.
John
JohnTN is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
