Sponsored by:
Sponsored by:
Rear suspension Question
Old 01-04-2011, 09:48 AM
GScott
GScott's Avatar
Default Rear suspension Question
Hello, I have a 1993 Gt Convertible 5.0. and I have looked in the Haynes manual and it tells you that the bolt to the top of the shock is under the carpeting and is accessed by opening the trunk or hatch. But the location for the top nut on the rear shock isn't mentioned for the convertible .I searched the forum but haven't found anything helpful. I am wondering if it can be accessed from underneath instead.
GScott is offline
Old 01-04-2011, 11:23 PM
petrock
petrock's Avatar
Its there. Take the carpet out and the panels out and you'll see it.
petrock is offline
Old 01-05-2011, 04:42 PM
Z28KLR
Z28KLR's Avatar
If you can't get to it from the trunk, try (with the top up of course) getting it from behind the back seat. I know we have different generations of Mustangs, but chassis-wise they're closely related and that's how I can access my upper shock mounts.
Z28KLR is offline
Old 01-05-2011, 04:44 PM
GScott
GScott's Avatar
So, they are further back behind the plastic pieces that hold the carpet down?
GScott is offline
Old 01-05-2011, 04:50 PM
GScott
GScott's Avatar
Thanks, I will take a look at that too, it looks tight up under where the roof is stored. I couldn't see the top of the shock from the trunk at all. Pics would be nice if you know where I can find one on the forum.
GScott is offline
Old 01-15-2012, 12:33 AM
MustangSD
MustangSD's Avatar
I am in a similar position - needing to replace rear shocks in my 90 5.0 LX. I purchased the chilton manual for aid on the project....ended up doing my own OJT and found the top shock mounts most accessible under the vinyl top well behind the rear seat (with the top up the vinyl well comes out pretty easy - a snap/channel moulding and a sheet metal screw or two. Now I seem to need a short open box end wrench and something to hold the shaft from turning - (a socket and extension turn both the nut and shaft). Hope this helps you take the next step. Any tool recommendations would be welcome.
MustangSD is offline
Old 01-15-2012, 03:09 PM
petrock
petrock's Avatar
The top of the shaft should have some flat sides that you can put a wrench on. Measure it with a caliper/micrometer and buy the wrench to fit (best), or a good adjustable wrench that won't un-adjust as your working (OK, but risky). Good luck...
petrock is offline
Old 02-29-2012, 08:46 AM
toplessLx
toplessLx's Avatar
Its actually really simple. Take the carpet off the sides. Find the wheel well and go to the top of it. You will find the bolt. Hold the stud with a pair of vice grips and loosen the nut with a wrench
toplessLx is offline
musnicki
09-23-2015 07:11 AM
raleigh05GTO
09-04-2015 07:09 AM
cbird1177711
09-02-2015 08:51 PM
09-02-2015 08:40 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Rear suspension Question
