Sponsored by:
Sponsored by:
2008 GT post-tune "pinging"
Old 03-02-2012, 11:29 AM
08_Black_vert_GT
08_Black_vert_GT's Avatar
Default 2008 GT post-tune "pinging"
I recently added CAI and a Bama tune from American Muscle to my 2008 GT. On the first runs after the tune I experienced "pinging" also known as "detonation" - at every tune level. Street, Performance and Race. It happens relatively consistently at 5,000 RPMs. Before I go back for a retune - any ideas on what to check?
Yes, it is tuned at 93 Octane and I only use 93.
Please help - thanks
08_Black_vert_GT is offline
Old 03-02-2012, 09:51 PM
ryan1994mustang
ryan1994mustang's Avatar
you would have much better luck posting this in the 2005+ section. the convertible tech section is only for issues directly related to the convertible top.
ryan1994mustang is offline
Old 03-02-2012, 10:12 PM
zanypunk
zanypunk's Avatar
When you post something like this you need to tell the Mileage and other things you've done to the vehicle or else no help :P
Note: When you return to the tune to stock, does it still detonate? If so, then it's the tune. Over-advanced ignition timing, but I don't know since you're not being detail. To be honest it could be a lot of things, it's just a matter or pin pointing things. Just following the chart. :P
zanypunk is offline
Old 03-09-2012, 02:08 PM
AMChrisRose
AMChrisRose's Avatar
There's a few things that I like to do, just to make sure it's not something underlying that may be causing the pinging.
1.) Make sure to fill up at a brand name gas station (Sunoco and Shell are the best).
2.) Clean your throttle body. This is the most common cause for idle instability, fluctuation and pinging comes from a dirty throttle body or dirty MAF sensor. Cleaning both of these really good is a smart move and isn't bad for maintenance, anyway.
3.) Fuel filter. This is also huge. I'd say this is the most common problem for pinging specifically.
4.) Check for any apparent vacuum leaks, go over couplers on the CAI, coupler to the throttle body, etc.
Once you've done all of this, if the pinging persists, give the Bama team a shout! They're really good at trouble-shooting this kind of stuff and can check the tunes to make sure it's not something that was done wrong on our end. It could be a 10 minute fix on our end!
Hope this helps get you taken care of. Give me a shout if you have any questions at all or contact the Bama team and you'll be running good in no time!
AMChrisRose is offline
JDWalton
09-24-2015 08:47 PM
Glocker23
09-23-2015 08:19 AM
rocky321
09-15-2015 10:00 AM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: 2008 GT post-tune "pinging"
