rag top separating from rear window. Help!
I've got an 05. Recently the convetible top, where it overlaps and adheres to the outside edge of the rear window, is separating; right now about 60% is separated. I want it fixed and I'm concerned about water issues but it's been bone dry here in Atlanta lately, thankfully.
Is this a repair I can do or does it require a dealer? If it's something I can do, does anyone know what I should order to do the repair properly?
Thanks All!
Mike
Thanks All!
Mike
Most places will say go for a full top replacement.
If you want to try salvaging the existing one, this might help:
http://forums.corvetteforum.com/c5-g...efasten-3.html
I would not take it to a dealer, I would not even THINK about taking it to a dealer.
You need a pro top installer. Even if you have to pay when ordered and drive a distance to have it installed. There is a definite art to a convertible top.
Maybe they can fix yours, maybe not. But a pro installer is worth the cost.
I forgot, there should be a screw & bushing kit available for your particular model. These bushings should be a good, easy & inexpensive DIY project. It would be a good idea to have these parts replaced before you have the top serviced or replaced. Then the top will look and perform as new.
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
