Sponsored by:
Sponsored by:
Late Model Resto lines don't fit
Old 02-23-2013, 05:54 PM
Slick68
Slick68's Avatar
Default Late Model Resto lines don't fit
I have an 88 GT Convertible. We bought it back in May '12, and the top would go down fine, but would need assistance going back up. The PO said he thought the cylinders were leaking because he would usually have to top off the fluid. I talked to a guy a few weeks ago that said the lines usually go bad before the cylinders, so I ordered a new set from Late Model Resto. I just came back in from a greuling 2.5 hr escapade of getting them swapped out only to find they won't work!
First off, the hoses are 2 different lengths. Neither are as long as the factory lines, but one fits fine, but the other is too short to reach the bottom and also too short to reach the top line if routed correctly. It fits if It's routed over the top of the cylinder, which causes it to rub against the hinges when dropped. Also, the fittings won't tighten into the top location of the cylinders. They screw in fine to start with, then right about the time they should start to cinch down tight, they just keep turning.
Has anyone else had a similar issue, and what did you do to fix it?
Slick68 is offline
Old 02-25-2013, 09:37 AM
Jarrod@latemodel
Former Sponsor
Jarrod@latemodel's Avatar
Slick68,
I haven't heard of this problem before. If you can, please contact us by phone. We will be more than happy to get you taken care of.
Jarrod@latemodel is offline
Old 03-21-2013, 07:49 AM
Slick68
Slick68's Avatar
Jarrod, thanks for the reply. I did call and talk to someone on the phone, and he tried to help as much as possible. One of the problems was definetly the cylinders. The top section that was plastic had stripped threads keepin the fittings from tightening. I replcaed the cylinders, and the lines are still on the short side, but I have them somewhat tucked out of the way, and will just wrap some heater hose around them to protect them for now.
Slick68 is offline
Old 03-21-2013, 08:12 AM
Jarrod@latemodel
Former Sponsor
Well I'm glad to hear that you called in. If you have any more problems, or if you need anything else let me know.
drfister
05-03-2018 10:38 PM
NorthAmericanTuning
11-09-2016 11:44 AM
yurizx6r
08-24-2015 05:48 AM
HillbillyLambo
08-21-2015 10:07 PM
08-12-2015 05:39 PM
Quick Reply: Late Model Resto lines don't fit
