Sponsored by:
Sponsored by:
Need help with top not working on 87 Mustang
Old 05-23-2015, 11:07 AM
jruppert
jruppert's Avatar
Default Need help with top not working on 87 Mustang
I bought this 87 last year around September. When I bought the car, the motor worked but one of the lines (hoses) leaked. In October, I had a heater core issue that required me to pull the dash. After doing so, the top stopped working. What I hear at this moment is clicking. I pulled the seats and inner quarter interior panels to fix regulator bushing issue and while I had everything out I thought I would check it out. So what I hear at this moment is the clicking on one relay and with parking brake set I hear clicking on the other relay. 2 relays total. I have yet to check to see if I have power going to the motor. I feel somewhat dumb to post this since since I have not checked for power. I am in the process of locating a volt meter. Assuming I have power to this motor, it should work. If I have power going to the motor, then the motor must be bad. Just kind of odd or coincidental that this thing worked prior to pulling the dash.
jruppert is offline
Old 05-23-2015, 01:06 PM
jruppert
jruppert's Avatar
I traced it back to a 25a circuit breaker under the dash. Had no idea it was there. Got it working..
jruppert is offline
Old 06-12-2015, 10:03 PM
302Ragtop
302Ragtop's Avatar
I had the same problem I couldn't find the breaker it is tucked up under the dash if anyone is having this problem it isn't on the fuse panel.
302Ragtop is offline
Old 08-08-2015, 07:06 PM
Omgitsa88Stang
Omgitsa88Stang's Avatar
This is good to know I have an 88 convertible and I have to pull my dash off to fix my heater core and replace my evaporator so I'll pay attention to this. Where exactly is the 25a circuit breaker located?
Omgitsa88Stang is offline
Old 08-31-2015, 06:41 AM
bonesnizz
bonesnizz's Avatar
it sounds like a bad ground wire. you might have knocked it off while working on the bash.
bonesnizz is offline
Old 09-24-2015, 12:57 PM
jc409
jc409's Avatar
I have a 92 with the same problem....where exactly would I look for that breaker?
jc409 is offline
Old 11-09-2015, 07:45 PM
302Ragtop
302Ragtop's Avatar
It is on a wire electrical taped together behind the steering wheel. It is tucked up pretty high.
Old 03-14-2016, 01:12 PM
jc409
jc409's Avatar
I'm at a bit of a disadvantage in that I'm at my place in Canada and my car is sitting in Florida so I can't run out and check it but I do remember that I saw a finger sized harness taped together with electrical tape and it had a blue or green fuse sticking out of it. I did check that fuse and it was good. It definitely wasn't a 25 amp circuit breaker as described above by jruppert. So for clarity 302Ragtop would it be a normal automotive fuse as I described that I found or would it be the larger circuit breaker with the silver colored exterior? Any help on this is appreciated. I'm heading back down at the end of the month and would like to get the top working.
jc409 is offline
Old 04-18-2016, 12:05 PM
paanmu11
paanmu11's Avatar
I have a 83 Mustang convertible top will go up but not down. Switch seems to be working but get nothing when I try to take it down.???
paanmu11 is offline
Old 12-01-2016, 03:54 PM
302Ragtop
302Ragtop's Avatar
One of your relays is probably bad they are located behind the back seat. One is up one is down.
Diode Dynamics
28
05-26-2022 12:02 PM
importsmasher
10-09-2015 04:42 PM
robjh22
08-17-2015 07:35 AM
daytooday
08-11-2015 09:22 AM
Mustang Sally72
08-11-2015 07:54 AM
Quick Reply: Need help with top not working on 87 Mustang
