My 1988 GT's clear coat is flaking off in a few spots on the roof and hood. How would i fix this? Would wet sanding the flakes off and putting 4-5 layers of clear rattle can and buffing it out help? its a white car.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
I wouldnt want to get the whole car repainted.. The rest of the paint is in excellent shape. I wouldnt be able to sand it down until its smooth then repaint it? Not looking for anything perfect. In fact i would be rattle canning it then rattle can clear it then buff it out
You're getting clearcoat failure in the most common areas. No real easy fix for that, we're not talking about a scratch through the clearcoat. Your basecoat is probably toast as well. You're experiencing clearcoat delamination from basecoat technically.
You could use a fine grit paper like you mentioned and use the rattle can, but your best bet is to repaint, especially if you intend on keeping the car for some time anyway. Good luck man.
__________________
01 gt, 75mm prof prod throttle body and upper plenum, bbk cold air intake, march underdrive pulleys with sfi approved balancer, pypes long tubes and off road h-pipe, magnaflow mufflers, 4.10 ford racing gears, ford racing carbon fiber limited slip kit, granitelli tuner, ford racing b springs, drifz gtr 17x9,www.twistedstallions.com FOR SALE$9000 PM ME
my cousin had a 89 in 89 and had to hav ethe car repainted under warranty back then. I guess this was pretty common. Took a while for yours to show up.
__________________
2006 GT 5 sp, vista blue, K&N filter only, SCT tuner, pine scented air freshener, those chrome door lock plungers, chrome valve caps
13.51 @ 102.75
Do it right. Have it repainted. It may be that you can have the clear removed around the affected area, leave the base coat, and just reshoot the clear. That would be something to be determined by the body shop though.
