Quote:
Originally Posted by crug75hid
i dont think it needs a repaint. spots still display paint there. you will need some touchup. may be that also wont be necessary if rubbing will help in getting those spot away
are you not looking at the same picture that i am, because putting rubbing compound or polish on that isnt going to make it better. you do realize that the clear coat is flaking off, don't you? but anyways, back to the OP, i personally would have the whole thing repainted, not just recleared. you might be able to get away with it being just cleared, but those spots where the clear is gone now have probably faded some, depending on how long the clear has been failing. so if you just strip the clear and recler it, then it might still look splotchy because of paint fade.
