Just keep it out of the sun and garaged as much as possible. When I bought my car 3 years ago the lenses on my headlights were horribly fogged. You can bring them back to life by wet sanding them by hand, first with 2500 grit followed by 3000 grit, then buff with compound and a wool pad followed by polish with a foam pad. I did this right after I bought the car and they looked brand new again and are still holding up well. And obviously, you'll need to remove them from the car to do this, and you'll need an extra set of arms to hold the lamp assembly while you're buffing them. I haven't tried any of the lens rejuvination kits on the market, so I don't know how well they work. Aside from that, I'm unaware of any products that will protect the lens coating.
__________________
2001 Laser Red GT; BBK cai, Professional Products 75mm tb/plenum, BBK udp's, BBK o/r x-pipe, SLP LM2 cat-back, FRPP 4.10's, SSBC slotted rotors, Eibach Sportline springs, MM c/c plates, MM lca's, BBK strut twr. brace, Steeda Tri-Ax, SPEC Stage 1 clutch, SPEC Billet Aluminum flywheel, Diablosport Predator tuner.
Sitting in a box: MM full length subframes
