Go Back   MustangForums.com > Ford Mustang Tech > Detailing
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-06-2009, 10:57 AM   #1
hookedonkronik
hookedonkronik's Avatar
Default Rim Cleaning Question
Hello,
I have a 1997 v6 mustang with stock steel rims. Over time, they have accumulated a good amount of break dust (especially after my brakes got really low), and even though I try to clean them frequently with soap and water, the dust has accumulated and is on the rims pretty good, especially the front two.
Does anyone have any good tips to get rid of this dust accumulation and make my steel rims look like new again? It's bad enough they are ugly rims, but now the front two look significantly darker than the back two.
Any advice is much appreciated,
Thanks.
hookedonkronik is offline   Reply With Quote
Old 11-06-2009, 03:15 PM   #2
SilverNGrey4.6s
Vehicle: 02 Ford Mustang GT and 03 Crown Victoria PI
Get some break pads that product low dust. I have Hawk ceramic pads and I get little dust. To get the dust off buy wheel cleaner spray that should work. Then after that just keep them clean with soap and water more often so it dosent build up on you.
__________________
2003 Grey Crown Victoria Police Interceptor the DD stock
2002 Silver Mustang Gt not stock
JLT Cold air intake
Accufab 75mm Throttle Body & Plenum
Mac longtube headers
Dr.Gas o/r x
SLP Loudmouth 1
3.73 gears
Steeda tri ax short shifter
H&R sport springs
Tokico HP Shocks & Shruts
18x9/18x10 Black chrome bullitt rims
SCT Xcal 2 tuner done by JMS Chip and perf.
http://Centraltexasstangs.com
SilverNGrey4.6s is offline   Reply With Quote
Old 11-09-2009, 11:15 AM   #3
Mirage
Vehicle: 2002 Mustang V6
Quote:
+1
When you finish cleaning your wheels off, give them a good thick coat of wax, the cheep turtlewax stuff works great. This keeps them shiny and helps repel brake dust. If they are realy filthy you may need to use 000 steel wool followed with rubbing compound and some wheel polish. All I need to do for mine now is a quick wipedown with a dry rag about twice a week (genaric brake pads).
Mirage is offline   Reply With Quote
Old 11-09-2009, 11:35 AM   #4
99 GT vert
99 GT vert's Avatar
Vehicle: 1999, Ford, Mustang
Send a message via AIM to 99 GT vert
are they steel like black finish or poweder coated aluminum (most stock wheels are this) and if they are the aluminum i would get some metal rx from obsessive detail
__________________
99 GT vert is offline   Reply With Quote
Old 11-09-2009, 12:33 PM   #5
Juztang
Send a message via AIM to Juztang
I would go with OD Metal Rx to clean them up. The Metal Rx also leaves a layer of protection behind, so brake dust won't build up as bad.
__________________
http://www.obsessivedetail.com Your source for high quality detailing products and accessories.
2004 Saleen S/C #170
Juztang is offline   Reply With Quote
Old 11-09-2009, 02:18 PM   #6
Jim D.
Try Eagle 1 All Wheel & Tire Cleaner and let it work for 30- to 60-seconds and scrub gently with a wheel brush. You may have to repeat. You can get it at just about any auto supply store or probably even Walmart for about $7 or less.
Once clean, wax your wheels and use a spray wax or detailer frequently to prevent further buildup.
__________________
Saleen Owners & Enthusiasts Club
http://soec.org
http://saleenregistry.org
Jim D. is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
