Pony Delete grilles
Pony Delete grilles
This is probably a stupid question but how do you remove the pony thats already at the grille? Does the "delete" in the kit give you direction on how to remove it? I want to purchase a pony delete kit, link below, but not sure how to remove the pony and the ring around it. Looks like I have to remove the bumper but not sure. Wanted to ask before I started.
http://www.americanmuscle.com/black-...te-grille.html
if you look where the product description is, right next to it is a tab that has the full instructions with pics for removing the old one and installing the new one. looks pretty simple, and no bumper removal.
Installation instructions can be found here: http://www.americanmuscle.com/pony-d...4-install.html
I hope this helps.
Let me know if you have any questions in the future!
I looked at it again and its hard to explain. The pony and corral is attached in the middle with star screws it looks like. But if I take it off, there will be plastic right down the middle where it was. Vertically down the middle. That piece is a solid piece that goes all around both sides around my lights. Its attached to my bumper too. Not sure if thats supposed to come off. I just want that pony and grille off and the front being wide open but the huge hard plastic thing is in the way. People are saying 4 screws and then taking a 7mm ratchet for the bottom, but thats the grille itself. Mine is not a grille. Just attached to a big plastic piece. Pics are below.
Look at the picture under step2 of the instructions: http://www.americanmuscle.com/pony-d...4-install.html
you should still have those 4 bolts holding that center-post section onto the bumper. Remove those and the whole grille-frame and pony should come out.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
