Discoloration and bubbles in primer
Old 09-02-2014, 11:22 AM
vincep99
vincep99's Avatar
Default Discoloration and bubbles in primer
I hope someone out there can help me. I am fixing 2 rust spots just ahead of the rear wheels on my 2007 GT. I stripped it to bare paint, blew it off with 90 PSI air, cleaned it with Wax and Grease remover (PrepSol), then shot it with a Devilbiss HVLP using matrix epoxy primer. About 2 hours later I saw tiny yellow drops forming on the surface of the primer. Sanded it bare metal again, this time used an etching primer. Did the same thing. Can't be water in the air lines since the etching primer was a spray can.
Does the Mustang use galvanized steel, and maybe this requires special prep? But I've done other spots on the car and never had this problem.
Was not that humid either.
Attached Thumbnails Discoloration and bubbles in primer-rust-002.jpg   Discoloration and bubbles in primer-rust-003.jpg
vincep99 is offline
Old 09-25-2014, 03:39 AM
buster
buster's Avatar
stay tuned to this, I'll show/ask my buddy who is a class A body man. My guess is that its bad prep a the factory. Or if you can't wait,(I have no idea when I will show this to him) take it to reputable body shop. They should give you a good opinion.
buster is offline
Old 10-03-2014, 12:07 AM
buster
buster's Avatar
showed my buddy this. Exact words : Take it to a shop and have it fixed. You're just going to make it worse if you try to patch it and then it costs more to fix it later
buster is offline
Granatelli Sales
01-20-2020 12:34 AM
guitarman376
10-11-2015 01:47 AM
shrkbate
10-02-2015 08:25 PM
GLOCKer
09-28-2015 07:36 AM
stealth_GT
The Racers Bench
09-22-2015 02:19 PM
Quick Reply: Discoloration and bubbles in primer
