Go Back   MustangForums.com > Ford Mustang Tech > Detailing
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-18-2007, 04:50 AM   #41
POIZNES
Default RE: Custom Interiors
and this is what it looks like when you take your time prime prep and smooth everything and use a basecoat clearcoat system for paint... and buy new steering wheel seats and other misc parts
[IMG]local://upfiles/58575/0FE7CBF4CDB44F53BAE60D92316B4F33.jpg[/IMG]
[IMG]local://upfiles/58575/51DA58D8310840F9B86E78D5A5FA7605.jpg[/IMG]
POIZNES is offline   Reply With Quote
Old 02-22-2007, 11:36 PM   #42
ts91stang
1991 Ford Mustang
so you dont recomend trying to dye the carpet?
ts91stang is offline   Reply With Quote
Old 02-25-2007, 10:15 PM   #43
Asbury030
Send a message via AIM to Asbury030
Hey guys wellI have a 91 mustang and I want all my panels to beblack what do you suggest?
__________________
Asbury030 is offline   Reply With Quote
Old 03-03-2007, 11:57 PM   #44
95viperred
how do i get these parts off?
i have everything else painted except this stuff
[IMG]local://upfiles/60064/8684F44912224EE5B680C8C4EC2ADBBC.jpg[/IMG]
__________________
1995 GT 5.0
aftermarket headlights, tailights, 5.0 bages, new viper red paint job, mac unequal length short tube headers, american thunder mufflers, flowmaster tips, march underdrive three piece pulley set, k&n air filter
95viperred is offline   Reply With Quote
Old 03-05-2007, 10:32 PM   #45
924banger
1992 Ford Mustang
Quote:
ORIGINAL: Asbury030
New ones.....i think there are some in the classifieds right now.
How do I get my plastic smooth? I am painting the defrost vent on my 92. I have about 3 coats on but don't really like the rough look. What do I need to do? There should be a sticky on how to smooth out factory rough pieces.
__________________
Red 92 LX mustang 4cyl
1992 Bronco 5.8L
2003 Cavalier 2.2L Ecotec
1993 Lightning #1579...Died 12/21/06
924banger is offline   Reply With Quote
Old 03-12-2007, 01:15 AM   #46
Stang Bang98
Send a message via AIM to Stang Bang98
i did mine black on black. it looks good, but my only problem is that the door panel must be rubbing on the dash next to the fuse panel on the side closest to the seats. this is happening on both sides at the same spot,and rubbing the paint off. i dunno what to do about it. I even checked to make sure the door panels were on properly. any ideas?
__________________
98 GT auto - B&M hammer shifter, MAC underdrive pulleys, BBK cold air intake, K&N filter, MAC offroad H pipe, AMERICAN THUNDER FLOWMASTER 40 series, FORD RACING plug wires.
Stang Bang98 is offline   Reply With Quote
Old 04-05-2007, 04:32 AM   #47
tommy2273boy
2003 Ford Mustang
tommy2273boy's Avatar
Vehicle: Maybe a cobra!
Send a message via AIM to tommy2273boy
here, I threw this together, tells a little more...
You’ll need:
- Sand Paper (fine grit)
- Lacquer Thinner (not paint thinner) and (should be liquid, not gel)
- Spray paint (Rattle-can)
- Clear Coat (NOT recommended for interior pieces)
- Clean towels
- Paint Area
Tips:
- Make sure its not too cold or too hot, 60* - 100*[/b] dry[/b] and no wind[/b] is ideal, and good ventilation[/b]
- Setup your paint area and stay out of the elements, such as wind or light rain. Do not paint in high humidity; the paint will not stick when it’s humid)
- I also recommend picking a factory color for trim pieces, so they’re easy to look up later on. Since my car is black/black, I choose Silver Charcoal from the 2003 year for my pieces. You can get paint from almost any car part store, my shop is Car Quest)
- Be sure keep the spray nozzle clear of paint build up. Hold the spray can about 5-8 inches away from the piece that you’re painting. Spray side to side and start before the piece and end after the piece.
- Hair dryer on low heat or a sunny day helps aid in the drying process.
Steps:
1. Wash[/b] it (soap and water)
2. Dry[/b] it (clean towel)
3. Tape[/b] off areas not to be painted (blue painters tape works well)
4. Sand[/b] it (all over and just enough to scuff it, you don’t need to go to the raw material)
5. Lacquer[/b] thin it (wipe it down with a towel dampened with lacquer thinner)
6. Dry[/b] (final wipe before we start)
7. Prime[/b] it (this is not always necessary, it helps as a base coat and fill in minor scratches)
8. Coat 1[/b] of paint (not a whole lot, just to cover most the item, still should be able to see the base still)
9. Dry[/b] (10-15mins)
10. Coat 2[/b] of paint (enough to cover the item and even out spots missed)
11. Dry[/b] (10-15mins)
12. Coat 3[/b] of paint (giving it a good final coat)
13. Dry[/b] (10-15mins)
14. Clear[/b] Coat (This is also not necessary, I prefer not to clear the inside parts, it might add unwanted glare. But if you are, repeat steps 12 and 13 as many times as you’d like using the clear)
The hardest part is if you taped off an area, you need to peel the tape before the paint dries to much, if you wait too long you can risk peeling paint off the part.
Let it all sit in sun for the day or by a heater for about 24hrs before handling. After letting it dry, take it back into your car and snap it back into place, be careful not to press too hard on the painted areas.
Disaster Recovery:
if your paint either reacts with the plastic or the paint runs (and in some cases it starts to rain on your project)...don’t panic![/b]
Stop[/b] painting,
Let it dry[/b],
Sand[/b] the effected area,
(you may also want to lightly wipe with lacquer[/b] thinner on the area)
Then repaint[/b] and blend[/b] in with the rest of the piece.
Do Not:[/i][/b]
- touch it[/b] with your finger(s) at any time (if you want to know if its dry or not, assume its not)
- load it [/b]up with paint causing it to run (there can always be more coats, get it next time)
- move[/b] it (ONLY if you really have to, otherwise leave it be)
__________________
K&N Drop In
X-pipe
MAC Catback
93 oct. Tune
tommy2273boy is offline   Reply With Quote
Old 04-27-2007, 02:54 PM   #48
Larry900
wow, very nice post, thanks for the info!
Larry900 is offline   Reply With Quote
Old 05-15-2007, 12:53 AM   #49
specialclay
Send a message via Yahoo to specialclay
That's nice and it's a plus that you did it!
__________________
Drive it like it was.....
specialclay is offline   Reply With Quote
Old 05-15-2007, 01:28 AM   #50
specialclay
Very nice
__________________
05, color, custom, custominteriors, customized, dupli, fabric, garage, interior, interiors, mustang, paint, pay, remove, vinyl
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
