Florida Regional Chapter Chapter President: ShakenRoush05
taking to long for idle to drop from cold start
Old 06-13-2011, 10:15 AM
kendrums1
kendrums1's Avatar
Default taking to long for idle to drop from cold start
1993 mustang lx with 2.3 from starting cold it takes 5 min for idle to come down to normal also 2000 rpm at start up,,,,, Help please
kendrums1 is offline
Old 06-14-2011, 02:04 PM
ShakenRoush05
ShakenRoush05's Avatar
Well it is always good to keep it simple! I suggest if you are able to do so, take a look inside the throttle body by loosening the clamp on the intake tube that will expose the throttle body intake. If you see that it has carbonized (very black and dirty) it will need to be cleaned. The butterfly may be hanging up slightly and sometimes it doesn't take much for this to happen. Once the engine begins to heat up all components will expand and this is why you may be experiencing a high idle condition and hanging when the engine is cold. If all checks out to be clean, time to put your car on the computer for some diagnostics. Good Luck!!!!!!
ShakenRoush05 is offline
Old 06-15-2011, 12:54 PM
kendrums1
kendrums1's Avatar
Thanks Shaken already did that it was the TPS playing tricks had to replace
Old 06-22-2011, 07:33 PM
racer44
racer44's Avatar
i was thinking IAC motor very common too
racer44 is offline
djbigskrilla
09-20-2022 01:04 AM
msavoia23
12
07-07-2018 12:08 PM
1987gt40ttopt
08-28-2015 10:49 PM
MXBT187
08-20-2015 02:36 AM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: taking to long for idle to drop from cold start
