- Select a Shift Issue
- FRPP K springs on V6
- wheels
- Has anyone else had this problem?
- 2014 gt500 bumper
- midpipes
- Will this gen V6 be enough power?
- Replacing rear shocks
- Long tube headers
- Time it takes for BAMA tune
- Round 3 Mods - Tune Time!
- Need a little help sorting improved clutch hydraulics
- My oil change monitor doesn't work
- Size of piston is Stock clutch master cylinder, ram slave?
- Has Motorcraft changed plug specs?
- 2012 3.7l bushings
- Average gas Mileage
- Unbelievable pricing on axle/cat-backs
- Which gear?
- Recommended 3.7 V6 Tune?
- Rear End Upgrade On '13 V6 Coupe Automatic
- Coolant Soaked Driver Floorboard on new 2014
- Why isn't 3.31 Rear end allowed for convertibles?
- Weird Clutch/Engine Issue HELP!
- Block Heater
- Tiny speckles in stock headlight covers
- 1st MOD
- BBK Tuned Length Shorty Headers
- How to take apart a tail light fixture?
- Engine Troubles
- BBK shorty headers with Borla- S
- LEAKING ANTIFREEZE
- Did I buy a lemon?
- Issue with sucking in hot air
- Throttle Body Boring
- Exhaust Help
- MBRP aluminized axle backexhaust
- Newby Seeking Advice/Help from Ford
- Timing Chain or Belt?
- Ford dealer idled my car for over two hours?
- oil - more for the discussion
- Had LCA's replaced but problem resulted . . .
- Anyone in NYC using a Bama tune?
- Rattling coming from front end??
- Sticking intake valve - any ideas on fixing the "bucket"?
- Motive Gears - no shims = whine
- Muffler deletes or aftermarket axlebacks?
- Finally got my BAMA Tuner!
- Time to upgrade my mustang, Ideas?
- Manifold vacuum hoses
- Round 2 Mods - Front to back, Jack!
- Mystery plugs
- Newbie Modder
- JLT oil separator install question
- What suspension mods to do first.
- 2014 crappy shifter linkage,115mph govenor, drive shaft issue
- Mechanical Hum at 65 Mph?
- 2012 V6 replacement grille
- A/F gauge? Will I need one later?
- bama tune warranty experience?
- Who has K&N Air Filterr?
- If you have 2013 V6/auto/stock...question on RPM in 4th gear
- Nav. question
- Adding shorty headers to Borla Atak Axlebacks
- Quick Magnaflow Exhaust Install Question...
- 2013 Mustang 3.7L transmission help
- Lowering Springs advice
- 2.5'' vs 2.25'' exhaust piping?
- Pegging MAF?
- 2013 v6 automatic 0-60 time help
- Who has installed their own long tubes?
- Extra fob What is it????
- Clunking Noise in front end in 2014 Mustang
- 2011 Mustang V6 3.7L - need some advice
- Performance package
- Local LA/Valley Transmission shops?
- Anyone with a 2013/14 V-6 auto and BAMA (not Obama) tune?
- Are there any spray kits for a 2014 V6??
- Oil Seperator Contents
- New 2014 V6, missing bolts on exhaust manifold?
- 2 Sets of Pirelli Tires Same Noise Problem
- Axle Help
- How to improve idle to 3k rpm performance?
- T.S.B's
- Regarding GT500 grill
- Blew AC line?
- P2111 code
- Dead Battery - 2014 Coupe
- Auto trans shift point recommendations?
- Somewhere between touring and s-type
- What to do, what to do
- ECU internal error
- Drive Shaft or Rims?
- Octane and tune question
- Ford Racing Touring Axle-Back Exhaust Advice
- How does K&N CAI compare to others?
- take good care of that Cyclone 3.7L
- What's Up With My Air Fuel Ratio???
- Automatic Windows Roll up on Closing / Arming the Car
- What order for mods?
- Passenger side Vacuum Line Needed BADLY
- I needs some help with wheels choices.
- Is there a diff between 91 octane gas and 91 octane ethanol gas?
- Storage
- 3.7L Throttle Response
- '14 V6 Base vs. '08 Pony Package vs. '15
- Spare Tire ??? Please respond.
- AM Modern Billet Grill
- Glasspack length questions
- Oil catch can on v6?
- ROUSH CAI or Airraid CAI
- Convertible styling bar
- O2 sensors
- 05-09 GT Axleback on 2013 V6?
- BEST APPROACH TO RACING FROM DIG
- I'm a hp/tq junkie...
- Seat airbags?
- 'Bama Tune for Dummies or Tuner 101
- running lights will not go off
- top speed is 115???
- best option:73mm throttle body or a roush exhaust??
- Would like some more experienced opinions on shifting issues on 3.7L M6
- Magnaflow axle back 15595 Street Series.
- What swayed you & Which Exhaust Choice Did Ya Make for the 3.7 L'il Animal
- Aftermarket (Cheaper) TPMS?
- Do LED Mustangs last dramatically longer with parking lights on?
- Hood struts
- Dry Nitrous
- HUGE FAVOR: Speed Sensor Voltages
- MGW Shifter
- Axleback Decibel Levels?
- Transmission Swap
- Front end noise, please assist
- Royal Screw Up
- Borla/Ford Racing Comparison
- p2254 '12 v6 3.7
- Downshifting speed/question?
- How to install resonators on the V6
- erratic idle
- CAI & TB, now need headers
- Headers and "H" pipe
- Exhaust drone from Bassani exhaust
- Big Creaking Sound Under Front of 2013?
- Sport Shift Mode Question
- Airraid + BBK Headers
- Airaid CAI install question
- Who has 4.10's and Auto Trans?
- Procharger Questions/Engine questions
- '13 Computer Screen Mounted Crooked. Are you kidding?
- Rear Axle Question
- '13 V6 "Shift Kit" feature :D
- 2014 shift problems
- Limited slip or not?
- New Mustang but coolant leak near reservoir
- Airaid CAI + engine cover
- New Clutch
- Water Sloshing Around INSIDE Driver's Door?!
- O/R X-pipe
- Strategy tune for emissions?
- Upper and lower control arm...
- Do you think this is reasonable?
- What can be done about raspy exhaust note?
- Lowering Springs
- Does the v6 performance package have to be special ordered?
- Fish-Tail out of a turn - Traction Control Off?
- What does CAI and exhaust do for a V6?
- 3.7 stock exhaust variations?
- Heat under dashboard drivers side
- shifting through gear racing with out using the clutch
- CAI/tune vs. axlebacks
- Automatic Transmission Problems
- Air/Fuel ratio ?
- OBD2 code "U0401" ?
- Limited slip differential an 3.73 gear
- 3.7L with Automatic; Burnout question
- Aftermarket shifter
- Round 1 Mods - Intake, TB and Tune
- Need some advise
- How much for Springs Installation?
- Are two oil catch cans needed on a V6 3,7 ?
- Recall & Bama tune
- Borla LT headers with BBK catted shorty x-pipe??
- How many people have changed driveshaft on 2011-present
- Stalling when A/C and recirculate is on?
- Dyno update in Tucson Az
- 3.7 shorties
- How Often Rotating 18" Pirellis? Handling Changing a Little
- Gears 2.73 to 3.73
- Anyone seen this intake in person?
- BBK LT fitment
- Borla ATAK or Touring with BBK LTs
- Upgrading my brakes. Are GT brakes better?
- 2011 v6 coupe injector noise
- gearing questions, auto too-low gear @ 45mph
- 3.7 Reliability Survey!
- BBK Headers
- Parted with my Procharged 2011 V6 today...
- Yet another exhaust thread
- Stock 3.7 strong enough for procharger kit?
- Eibach sway bar kit Review
- 2012: Oil all over right side under hood
- Why Is My Car Saying 29 Miles Until Empty With 2.5 Gallons Left?
- high fast idle problem, any sugestions as to why?
- Best Performance Cat-Back and CA legal?
- Stop Changing Your Oil Every 5,000 miles unless indicated by the CAR
- What else do I need for more power?
- need 2 new base v6 wheels
- Painting wheels
- Exhaust
- Speed up my stang
- Mustang appearance
- FRPP exhaust tips
- tax refund money help me spend it.
- Higher Octane = Higher MPG???
- Pro charger on the 2011 3.7 L
- ford racing cut & clamp x-pipe
- Just drove a 2013 v6
- nitrous on a v6 is it possible
- Borla S-type loudness?
- Recall on 2013 V6
- 3.7 v6 no mufflers = awsome...
- performance pack parts...how to find them.
- Interior Dome lighting
- Downshifting
- Clockspring question
- Cruise Control Button Peeling After Four Months
- anyone have auto tranny problems?
- 3.7 perf parts???
- 373's for 2012 V6
- 3.7L Automatic Gear Question: 3.31 vs. 3.55 vs. 3.73
- Pypes Pype-Bomb Axlebacks!!
- removing mufflers 2012 v6
- Forced induction options
- 2013 v6 driveshaft
- Different Mufflers for AUTO and MANUAL trans cars ???
- Quieter exhaust?
- First Oil change? Recomendations?
- Exhaust change?
- Rented 13 V6 Vert-my review
- 2013 MPG Question V6 Auto ~ starting in 2nd gear?
- Crosspost: 2013 Owners check your brake fluid reservoir
- So whats the deal with the governor?
- 2013 Hesitation/Stumble in middle of RPM
- exhaust system
- Is drive shaft need?
- 2011 Coupe Grille
- I have the 2011 3.7L v6 a/c trouble
- 12v source in engine bay?
- Hurst Billet Plus 2 Shifter vs Boss Steering Wheel
- Gauge Cluster Rattle 2012 V6
