- Traction Control Turns Off And On By Blinkers
- Turn signal electrical issue
- Stalling and turning on battery light
- Front license bracket
- 2012 17.8 MPG
- Would this short throw shifter fit?
- Does 3.7 L need a catchcan or anything else for longevity?
- Annoying squeak in rear while driving
- Who is the best tuner for the 3.7
- Engine vibration and rpm dip occasionally when idling and when putting in park
- OPT7 AURA PRO LED Lighting kit install
- Driver door subwoofer issue
- Need some info on my 2015 FordMustang V6 Fastback 3.97
- Engine rapid surge/misfire
- SCT X4 canned tunes vs Bama tunes for life
- Grinding gears
- 2014 v6 Misfire problem
- 3.7 Limp home mode - SOLVED
- 3.7 Electric gremlins from hell. Need help diagnosing
- Random Startup Problem
- Engine Noise at 1.1k to 2k rpm
- spark plugs for 2015 3.7
- Interior noise!
- 2014 Mustang V6 - What side is Bank 1 and 2
- ProCharger on 3.7L
- Props to American Muscle/Bama tuning 👍
- Sat. Nav.
- Brakes and traction control issues
- Extra Throttle Body Connection
- 3.7L Manual Trans RWHP?
- 2012 Mustang Shifter Issue/Possible Transmission Issue
- pinion nut torque
- Rear differential case leaking 2013 mustang v6
- Quieting SR Performance Exhaust Slightly?
- Long tube headers
- Underdrive pullys? Thermostat?
- Chirping sound from rear
- No signal from upstream o2 sensors on new to me purchase.
- Both traction control and traction control off lights turn on together intermittently
- trailer hitch
- engine code P0017
- Brake question
- Is this a rear gear whine?
- Loud noise during cold start
- air bags recall
- 2014 Mustang transmission cooler lines rattling noise
- Rough idle
- 2012 3.7 Resonator Delete
- 3.7 Bbk Shorty headers
- What’s the Valve cover torque specs and pattern?
- How much HP per mod?
- 2014 mustang crank relearn trouble help!!
- Electronic Throttle Control came on all of a sudden..
- Exhaust tip rattle?
- 3.7 V-6 throttle issue
- Gears or Exhaust Next
- 3.7L twin turbo ecoboost swap kit?
- Help with car codes
- Spark plug service interval?
- Exhaust Opinion
- pypes bomb axlebacks
- Replacement Engine - Rubbing Sound After 1 Week
- 13-14 driveshaft?
- How to change the function of the windshield Washer
- AC & Heat Temperature Issues
- 2012 3.7 Ticking/Knocking
- Mafia? Bama? or???
- Programmer
- Oil life dosen't change
- 3.7L man trans strength?
- Will 3.5 EcoBoost Exhaust Fit 3.7?
- Right Rear Brake Dragging
- Cam out of time
- Help Me Find This Video!
- Schrodinger’s Thermostat Housing Gaskets
- side marker flickering
- Gas not pumping
- Procharged 2013 3.7L
- Sync Stereo issues.
- Procharger build questions
- Mustang Build
- 2013 Mustang 3.7 V6 Cam-/Crankshaft Position Timing Chain Problem
- Issues with 2014 3.7
- P0201 thru P0206
- 2014 Mustang UnderCar Shield
- X-Pipe: BBK Catted vs Ford Performance Cut & Clamp
- 2012 3.7 won't shift. speedometer 0
- Turboing a 2011
- 2012 3.7 Popping Out Of Second Gear
- 2012 Mustang V6 Fuses for A/C and Wiper keep blowing
- 2013 mustang v6 AC problem
- 2012 V6 to GT front bumper swap
- SOLVED- Radiator Fan Squeaking after car is turned off
- Rough Idle / Vibrations / Rattle
- Clock spring and RCM bad?
- 3.7 Mustang 1/4 (and 1/8) Mile Time List
- BBK catted X pipe
- rear tire spacers AM
- Leaking coolant
- Throttle response
- 2012 V6 Convertible
- 2012 3.7 drive shaft
- gears
- BBK short tube headers
- What mods typically bring the best sound?
- Winter maintenance
- Shudder in neutral, goes away when clutch is depressed
- What needs to be done to beef up internals?
- Quietest muffler possible
- Torque for 2011 v6 3.7 water pump replacement
- 2014 v6 base model key stuck in ignition, can’t get it out
- Exhaust recommendation
- Twin Charging the 3.7
- Oh boy another ticking sound
- backup camera power
- Weird noise coming from the rear
- Getting 3.73 gears!!
- Front brake shudder
- Won't start nothing happens
- MT-82 transmission issue
- 2014 Passenger Side Wheel Rubbing
- warning lights stay on
- CJ Pony Parts Axle Back?
- 2014 V6 Vert Rattle sound
- Exhaust
- Rear brakes
- Water leak question
- Vibration under Engine Brake
- 2014 Ford Mustang Wire Diagram
- Water Pump Blues
- What in the world is the antifreeze problem ???
- Where is my Antifreeze leaking???
- Coolant Change Time Mystery
- New to this
- Borla Exhaust for 2011-2014 Mustang V6 3.7L
- Exhaust tips
- Supercharger V6
- A/C problem
- Question about power door locks
- 2014 3.7 V6 timing cover
- P068A Error and Electrical Issues. Help!
- Exhaust question
- 2013 V6 HARD VIBRATIONS
- BEST TUNERS FOR V6
- HOW TO REPLACE A WATER PUMP ON A 2013 V6
- Exhaust dampers
- 2013 V6 UPPER INTAKE MANIFOLD REMOVAL
- speedometer
- best BORLA DEALS
- 2012 trunk parts
- Problem Bluetooth mustang 2011 v6
- 3rd brake light
- Muffler recommendations
- Wobbling issue
- Paxton supercharger for 3.7L?
- Throttle body upgrade
- Any tuners compatible with Mac?
- Which tuner?
- Pedal Commander Throttle Response Controller?
- Shock Absorbers
- mid pipe recommendation
- 2011 mustang u joint
- Mustang 2012 3.7 V6 VIN Number
- 2012 Hesitation/Stumble on acceleration from a stop
- 2011 drive shaft
- Are the 2011 and 2014 Mustang 3.7 catalytic converters the same?
- Customer Satisfaction Program
- Tool icon on dash
- Anyone using an Optima Battery in their 3.7?
- Nitrous?
- Need help - transmission not shifting 1-2 at WOT
- 3.7 retune
- LT BBK headers install
- V6 to gtcs springs
- So what's next!!!
- Throttle body or mufflers?
- 2014 3.7 stalling randomly
- Power Steering Issue
- 95 3.8L overheating problems
- 3.7 bama tuner opinion
- Help needed with speed limiter and IDS
- just got a 2015 3.7 V6. what should I do?
- where is 3.7 Engine Serial # / Vin
- magnaflow comps or streets?
- Hate my Pypes exhaust. New Exhaust suggestion?
- Help! My Mustang is slow! 0-60 6.9!
- HEAD UNIT
- BBK X-pipe made car slow AF (help)
- GT airbox lid on a 3.7
- Need exhaust help, Please
- Sorry, gears again
- California, TUNING, and Octane levels.
- Tuner/CAI worth it?
- 2011 Water Pump Replacement
- 05-09 GT or 2011+ V6?
- Mufflers on Stock 3.7 stangs
- Cam swap on 3.7L V6
- Shorty h pipe?
- Twin Turbos, anyone?
- Buzz in exhaust
- HOW TO: Changing Transmission Fluid on MT82 Manual Transmission
- P0030 and P0050 codes
- Valve Rattle after first oil change!!
- aluminum light weight under pully 3.7
- blend door
- 2012 3.7 V6 water pump.. what's the trick?
- LT Header install issues
- Days of Modifying may be over for Our Cars
- Top Speed?
- First upgrades
- flashing icon
- Warranty
- New Gears at 7K miles
- Anyone PLEASE HELP! 'car Red Lines every time I race and won't go down =/
- 2015 mustang v6 with magnaflow axle back exhaust 19179
- Throttle lag,,,,,, gone
- Exhaust again!!
- Delayed Response & Hesitation (Different Maybe?)
- V6 next steps?
- Kinda Slow
- My V6 is having a strange bubbly engine noise
- 2011 V6 Mustang Mysterious Engine/Belt? Noise (w/ vids)
- Loosing coolant 2011 3.7
- Looking for License Plate Bracket
- New to Muscle cars
- Who can do a burnout with all stock and just a tune?
- Break Options
- What should next mod be ?
- Engine clicking.
- Common Problems – Looking to buy
- Question about automatic shifting
- 2011 Trunk lid fitment issues on 2014?
- Reverse to Drive Shift Time
- Remote oil filter set up
- Gauge cluster swap issues.
- Thought I'd share pics of my successful Push-to-Start/Remote start install!
- exhaust video as promised. lethyl
- Electric drive Serpentine
- 2013 Premium Auto Dimming Mirror
- Thinking of getting a V6 mustang have questions
- 3.7 loses power almost stalls. Turn off restart its Ok.
- 2014 mustang - Phone option on the stock stereo
- Odometer lights out
- Oil blow by with supercharger
- Exhaust Manifold flange?
- Coolant Leak - under oil filter
- Upgraded Fuel Pumps??
- Weird scratching sound from center console while driving
- tuner for3.7
