- Grinding in 3rd gear
- 3g alternator install probs
- over haeting ornot
- MOVED: door lock actuator
- MOVED: Gas Mileage
- MOVED: went and looked at a 1990 notch today
- don't hesitate
- losing voltage??
- 95 gt, runs great, randomly dies and sometimes wont start
- throttle cable length?
- installing upper control arms
- MOVED: What springs do I have. Pics
- Fixed CEL by accident
- Clutch Installation
- radiator fan?
- heads
- Rear Seat Delete.... How To?
- question for the e-303 guys...
- driveshaft install
- MOVED: 302 block with 5 grand to spend?
- Mac stubbie style headers 1987-1993
- oil/ps/trans coolers...
- MOVED: rant
- MOVED: Cheapest place for a Walbro?
- Starter relay?
- 347 stroker
- MOVED: Tail Lights
- motor swap
- MOVED: please help what should i get
- Trans Guys Needed...
- Timing chain gearset questions
- PCV screen/filter
- Smoke after intake install
- Car runs poor in cold loop.
- Harmonic Balancer Torque
- WHAT IS CONSIDERED A MILD MOD?
- post deleted
- engine work...advice and suggestions...
- Equal Length Header Install?
- Helppppp pleasee
- IRS from 03 cobra into a fox???
- Battery wont hold a charge
- gt40 head, valve spring question
- what size valve springs???
- need some help
- Witch Headers to buy???
- Flowmaster super40 question
- Can I pass Emmisions with no smog pump?
- e303 woes...
- Idler pulley
- Transmission Issues
- Intake Question
- 65mm Accufab T/B
- tranny problems
- pulled head
- unusual alternator problem? car was towed
- 5.0 or 4cyl conversion?
- ps cooler is it needed?
- C4 swap
- Possible head and RR swap!!!!
- Alternator overcharging
- Short throw shifter install
- New Mufflers
- T-5 rebuild, "world-class" and FRUSTRATION
- hi flow cats or off road that is the question?
- MOVED: Nearly stock 1990 GT vs. a 2003-2004 Mach 1
- MOVED: Rim Choice
- intake manifold troubles
- 24lb injectors
- dashboard swap how hard?
- difference between transgo shift kit and lentech manual valve body?
- hypertech work?
- Does the combustion size change compression?
- fuel pressure HELPPP
- Possible Cause of a Creaking noise driving me INSANE
- subframe connectors question
- Brake upgrade?
- torque spec on pinion nut
- sputtering?
- Bolt pattern for fox bodies
- MOVED: 88 5.0 smoked by 2000 Z28
- 9" rear in a fox
- which one to rebuild?
- Recognize this spring?
- transmission
- building a 347
- exhaust valve or rocker?
- Short Throw Shifter Install
- ACT sensor
- loose steering, yet another problem
- Trans Fluid?
- Rear end noise
- 5.0 swap from v6
- engine setup
- 86 302
- What mods can i do to my 5.0 CARB?
- rolling the fenders
- Crankshaftt pulley bolt size
- Quick tranny hELP!
- Fitting issues...I'm stumped.
- clutch cable
- Stupid Question
- Help Please I don't know what to do...
- gt-40 intake vs. stock
- alternator??????
- camber/caster junkyard?
- 4.10 gearing question for 89 lx 5.0
- PLEASE READ! ENGINE SPUTTERING at 3500rpms
- suspension
- Water Pump Direction
- It's Alive
- Need help with Rim and tire question
- Magnapacks and a fox
- HELP ON 89 LX MUSTANG
- a different kind of fan problem
- Hi Flow Cats Question
- turbo oil lines
- cobra grille install
- timing
- torque box
- rear wheel bearings bad?
- Which Throttle Body?
- Is anyone here using RHS heads?
- cats are going back on
- 302 swap in 4cyl.
- headers for yates
- going to be doing the rings....
- Smog pump delete
- Edition Lombardi 87 GT ????
- valve spring question for people with E303
- TFS R series Intake VS Holley Systemax
- MOVED: $4 gas? HELP Design fuel efficient hot rod ford engine
- Help with tranny mounts
- brakelines
- Kirban fuel pressure regulator
- exhaust question
- Brake upgrade
- MOVED: Looking to buy a 94GT, but need so Info..
- distributor wont turn
- 347 stroker build-up question
- 2.3 to 302 vert
- high idle after warm up.
- aod to t5 swap?
- electric fan
- MOVED: whats next question
- Building a stroked motor?
- new mustang
- brakes
- door locks
- when to weld frame rails?
- piston ring
- harmonic balancer?
- fox body hydraulic clutch
- speedo gear
- hard starts/stalls
- Egr elimination resistors??
- install of a 5spd pedals
- Help pulling a 5sp tranny out of a 92 lx 5.0
- Mass air computer C1A1
- sometimes she starts, sometimes she doesnt...
- vibrations/semi soggy brakes...
- Coil Overs
- MOVED: Which Mufflers to go with?
- whining sound from rear or driveshaft?
- bbk fuel pressure regulator is leaking
- Slipping Auto Transmission
- anyone got pics of eibach pro kit installed?
- MOVED: Tires/stance
- How do you confirm an SSP car?
- MOVED: how low should i lower my car
- cat smoking.
- MOVED: Ford Racing 9mm plug wires
- subframes
- HELP PLEASE! MAJOR PROBLEM
- coils spring isolator !!! HELP!!!
- Fuel Rails
- MOVED: H Pipe or X pipe on a 94 GT
- Battery charging problems...
- mustang v6 to v8 ??
- Car won't idle
- emitting black/grey smoke when at high rpm
- wiring questions
- Dead battery issue
- 89 mustang 5.0 lx
- check it out... remember the days
- backfire
- 94-95 gt or cobra
- Wheel hop after susp mods ? ?
- Timing cover differences
- Nuetral saftey switch bypass
- electric fan retrofit
- Help needed fast on intake manifold on 1988 mustang gt??
- chipped combustion chamber
- volts gauge bouncing at idle ?
- bench bleeding a master cylinder
- what do i do now
- MOVED: Well, my new wishlist
- Opinions & Help on my First 5.0 ENGINE BUILD
- MOVED: 87 to 93 GT fog light question
- intake manifold swap
- MOVED: '93 cobra parts
- MOVED: Broken Back.
- air pump check valve
- 89 notch with AOD problems
- search broken injector questions
- Core Support Damage
- engine rebuild
- benefits of EGR delete?
- Roll Cage
- oil pressure
- off set/ back spacing wheels???
- How do you wire a Altenator
- MOVED: anyone take off their power steering? i need the ps return line the metal part
- power steering metal return line
- getting supercharger
- Engine Overhaul
- MOVED: GT Taillights
- Vert top pump
- AODE problem?
- car died....need some help...
- MOVED: vettes
- Fox body with 5 lug, ball joint and front end ?'s
- shift linkage and gear ?
- Starter relay/solenoid- wiring help
- how do you get a drivebelt to tension
- NEED HELP WITH THERMOSTAT!!
- Rearend Question
- 93 Cobra intake on a 94 GT
- Borgeson aluminum steering shafts
- GT40 and stocker.
- oil leak
- pcv valve
- need help please
- That little steering shaft collar that attaches to box
- csr water pump
- trw L2490 in a 302
- efi to carb
- MOVED: bullit rims of fox
- Help needed on Harmonic Balancer and Flywheel.
- what is a gt-40
- 2.3 to 5.0
- MOVED: 88-89 Convertible Front & Rear Speakers ???
- upper tq boxes
- melling products
- Rocker Q
- 347 stroke?
- sn95 full front suspension
- Best Bolt Ons 5.0 ???
- 65mm throttle body Up grade??
