- kinda pissed (kinda not)
- Listen to this GUYS!!!!
- exhaust
- Alum Rad, Electric fan, and Alternator setup?
- 347 clutch help
- i did search, help with idle issues
- Electric Water Pump on a real DD
- Mac Prochamber onto FlowTech LTs?
- 5.0HO mods... help
- puck style racing clutch's any good?
- Torque Arms? Are they worth it?
- paxton sn 89?
- Can you make struts work on 79-86 mustangs?
- TF Twisted Wedge top-end kit vs. RHS 200cc SB Cylinder Heads
- any1 have TNT Imma gonna blow it up
- 351 on 302?
- MAF and Idle questions
- water from tailpipes?
- Head Qs? Not the normal Qs.
- high idle problem
- weatherstripping/molding question
- Idle problem
- bad news
- Torque converter advice?
- 89 5.0 LX, 7.5 or 8.8?
- MOVED: MGW or Steeda Tri-Ax
- MOVED: ET?
- turbo question
- Do I need to upgrade my intake?
- what should i add?
- 93 GT: propper TB size, equal vs. non equal header Q's
- Fox parts interchange?
- Tranny question
- Good cam for GT-40ps?
- noob 5.0 ?
- Coolant problem
- MOVED: What do you think about ebay???
- Rear coil spring spacers
- control arms
- ok what the hell? need some help quick!
- o2 sensor wiring (megasquirt)
- AOD Question
- Electrical Nightmare
- Tranny Fluid?
- finding a computer
- New Website for American Muscle Appreciation
- Evac System
- harness vs. 4 wire for mass air conversion
- heating issue again
- gt40p head question
- HELP with H.I.Ds in a 5.0
- Tubular GT-40 intake
- stock 5.0, can i go nitrous?
- What size gears are stock in an 85gt
- 5.0 swap help
- MADE A STUPID MISTAKE (SPARKS AND SMOKE) HELP PLEASE!
- Steeda #19
- 3.73 Vs. 3.55
- lose weight..
- MOVED: chrome dipped
- rocker stud girdles
- MOVED: so, who wants to hear my II running?
- I need someone who knows axle seals,
- minimum to reach 600 rwhp
- Longtubes and emissions
- 1.5 inch lower exhaust question
- Best shocks for all around
- T5 2 AOD?
- how to care for a 95 with 182.000
- Heater core how to?
- speed density how to's wanted
- upr k-member kit
- rattle clunking sound clutch
- fuse help please
- how much nitrous can stang take????
- real quick question 3g alt install
- Anyone using GT40-X heads...
- clutch pressure again?!!!
- MOVED: Tis a Sad Day in the 5.0 world.....
- door lock
- What is this?
- Weird problem
- whats wrong with my ponny!!!!!!!!!
- longtube headers and automatic?
- 1990 5.0 Problem at Low Idle.
- Cold Air Intake
- help installing window motor
- SN-95 Brake Question
- how much stronger is a mexican block?
- 88 GT T-Top running (rich)?
- soft brakes !
- Help with MAF and air tube for EFI swap
- Newbie Here...With A Swap Question
- Heads- Holley or Trickflow Or Edelbrock
- need some help please**updated with pics*
- Stuck throttle body to intake suggestions?
- thinking of doing a 4 eye conversion
- cmputer swap????
- wheel sizes
- how do i make my clutch cable adjustable?
- Head Gasket
- Header install gasket matching ?'s
- 89 gt gears
- knocking sound
- quick harmonic balancer question
- 1990 Rear Quarter Panel
- Harmonic Balancer Install
- frame strength???
- New Rack and Pinion Steering Boots leaking
- Starting Issues
- thread for rocker and pushrod install
- venom 400?
- Engine swap.
- bad sounding noise
- AFR pushrod length with 1.7 pedestal RR
- HAVE THIS HAPPEN TO ANYONE BEFORE?
- whole floor replacement
- rear (not a gear ?)
- random problems, suggestions??
- Somethings F***ed up!
- are these intake, head, cam, etc. combos worth it?
- suspension questions
- Best Budget combo
- E303 pass smog?
- pedestal or stud rockers
- MOVED: Is this worth $3k?
- whats needed to install an electric fan
- How in the sweet jesus do I get at these bolts?
- MOVED: Dress up!
- clutch and cable recomendations??
- Rocker Arm Studs
- MOVED: My '91 Convertible project for $450
- Automatic Trans.
- MOVED: Help with picking Exhaust
- stroking my 5.0 questions
- 69 ford 302 power limitations......
- can i put 4bbl on fuel inj/blk and keep cam
- Need help on picking between Control Arms
- exhaust smoke is too white
- ebay twin turbo kit (good or no good)?
- what intake to use
- Front Subframe Bolts
- wideband o2's
- more horsepower.
- idle problems
- BBK SSI Numbers
- id number on rear end
- Dimming Lights/batt gauge...
- car starts in reverse not in park??why
- E303....problems?
- neeed advice on upgrades
- MOVED: park the 5.0 in the rain and get a Subaru WRX? How do these compare?
- Alternator Gague Question
- engine question
- 331 or 408
- what size TB is stock on a 95 5.0?
- 65mm and 70mm difference
- When it comes to headers..
- 95 induction which is better
- Victor 5.0L Intake
- MOVED: pics and a vid of cam swap in 93 lx
- MOVED: I need a Cold air intake?
- Fox Headers on a SN-95
- T5 input shaft play
- Lincoln mark 7 rear end question
- Speed Density
- MOVED: fox fender extensions
- MOVED: im new to sn95's
- MOVED: 182,000?
- shift kit for auto
- trans question
- anyone head this issue?
- Kenne Bell SC Question?
- bearing clearance
- MOVED: CANT believe my car is CRACKED I got CHEATED??? help what can I do
- MOVED: found a 84 5.0 for 800
- Locked out of trunk
- IS THIS POSSIBLE??
- vortech question
- 1987 Mustang Gt
- Spindles swap ?
- MOVED: bought another fox!!
- MOVED: which charger?
- MOVED: 1984 5.0L GT vs non-GT
- new exhaust parts - need answers
- MOVED: Best way to spend 5,000
- MOVED: astro performance
- Engine performance problem
- coolant problem
- Belt Size
- Anyone With a 2-step
- gas smell:::
- thermostat tidbit
- What's my cam?
- please help auto tran wont shift to drive
- Another "will this tap the piston" question
- what can go wrong in the bottom end...
- Pulley Help!
- distributor
- engine help
- clutch pressure is gone
- MOVED: need help! cant decide
- MOVED: WELL I am HAPPY!!!
- MOVED: NEED PIC OF YOUR ENGINE BAY.
- cam bearing
- MOVED: A new 5.0 mustang from saleen
- Vibration...Hmm
- can anyone help on rpm problems?
- Header bolt length
- how to tell which lifter
- RE: one thing after another
- fast xfi vs. Accel dfi
- Tranny Crossmember
- Look at these heads and Rockers "pics"
- emission question
- timing gear set
- still no spark. cannot figure it out.
- Offset rack question
- g-force
- which valve stem seals???
- Weird Idle
- Mac Products & Trufiber Hood GP!
- valve spring keepers won't budge
- need to find a p/s cooler
- Question???
- Drag spool vs Locker
- whats the best timing for 90 5.0L?
- Finding a Clockspring
- supercharger help
- Springs and shocks on a fox
- water pump problems
- gauge needles
- Compression Ratio questions
- Timing set points?
- Proportioning Valve
- cam help
- IGNITION COIL
- first time doing a clutch help!
- 70mm egr plate to stock intake?
- MOVED: wheel size
- MOVED: 275s and foxes
- Bad Clutch????
- MOVED: pro 5.0 question
- TRANNY and IGNITION problem!!!
- MOVED: TIRE SIZE QUESTION
- Can you clean up Fouled plugs from Gas?
- trouble shifting in and out of gear
- how to convert to mechanical Roller cam
- RIM SIZE QUESTION
- C-6 or AOD
