PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 [102] 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. tried to tune the timing and cut out
  2. How much do these cars weigh?
  3. Rust problem, Any suggestions?
  4. tach wireing
  5. biggest lift cam on stock springs?
  6. Throttle body choice?
  7. 5.0 gt to 5.8
  8. E-303 question
  9. help with 302
  10. help with 302
  11. bad wiring??
  12. power steering pump question (adder you might know)
  13. new edge seats
  14. what should i do?
  15. Bad Vibrations- HELP
  16. Rattling noise/problem
  17. Rear End Drum Brake Swap Question
  18. engine help...need some help
  19. Timing cover gasket
  20. Flywheel
  21. Shifter
  22. 2 choices and another ?
  23. rings?
  24. What is this for?
  25. inncorrect fuel level
  26. Pushrod length???
  27. fan connector q
  28. Rear end Question
  29. MOVED: Smog Pump Delete in Arizona?
  30. MOVED: what brand of wheel is that
  31. bad wiring?
  32. motor not warming up?
  33. 331 question
  34. tire question
  35. control arms
  36. Smog tests and more bolt-ons...
  37. throttle body ?
  38. just put heads on....few simple questions...
  39. 1991 GT Conv won't start
  40. MOVED: Gears
  41. MOVED: i need pics of red 5.0's with gunmetal rims
  42. T-5 to AOD...?
  43. vacuum diagram???
  44. Spec stage 3 clutch or king cobra? Ram?
  45. supercharger
  46. stock block..
  47. tech help a/c delete
  48. camber adjustment
  49. Replacing heads help
  50. fuel filters
  51. Head Gasket ?
  52. Aluminum Heads Don't want to pay $1000
  53. Trans swap
  54. TWIN TURBO KIT
  55. How to determine TB size (measure)
  56. lincoln drivetrain will it work?
  57. Need help installing a gear drive
  58. Ford Racing Water Temp Guage installation
  59. block question
  60. what is necessary
  61. T-Top
  62. Transmission Troubles
  63. Good exhaust choice for 88 GT 5.0
  64. Rear suspension issue
  65. Timing Chain and Gear
  66. ultimate throttle response
  67. 83 to 87-93 master cylinder swap
  68. best "off the shelf" cam for my application?
  69. Drag Tires
  70. 1993 5.0 Clutch return spring???
  71. Anyone using Anderson Quick Kit 2 top end kit?
  72. A/C Delete
  73. Will 07 S281 wheels fit on a 87 LX 5.0
  74. 347 stroker...which heads?
  75. flywheel
  76. upr front suspension
  77. HO CAM SWAP
  78. Ignition & Key question
  79. C4 and C6
  80. Water pump
  81. MOVED: HOLY MOTHER#*@^$*%@*# Clutch Quadrant/Pedal Problems
  82. limp mode???
  83. Gas milage question?
  84. MOVED: What you think of this Stang?
  85. My steering gave out!!
  86. EGR DELETE
  87. alignment specs for a 90 fox?
  88. MSD Retard Module ?
  89. where to buy
  90. 1995 cobra Foglights
  91. clutch disk diameter
  92. planing to do a 5.0 swap for a friend
  93. motor is running too cool
  94. Lightning Motor into 5.0 Mustang.
  95. Shaking
  96. 302vs347vs351vs460
  97. 1st mod on stock 88 5.0?
  98. Strut Tower
  99. 255 lph fuel pump
  100. 87 vs 93 engine difference
  101. Steering Shaft
  102. Smog Pump issues
  103. pro m question
  104. 95 Mustang GT converted back to Fuel Injection
  105. biggest tire on 9" rims
  106. tranny question??
  107. die after cold start
  108. someone help (adder u might know the part#)
  109. Suspension Issue
  110. a little different gear question
  111. heel toe and sparkplugs
  112. airbag light blinking
  113. air bag light
  114. Help reading carb spec sheet
  115. what kind of intake manifold is this?
  116. Transmisson Whining???
  117. Idle Surge?? HELP
  118. clutch help plz
  119. help! need parts.
  120. 88 gtdies like i turned the key off
  121. Spark Plug Gapping
  122. thanks guys for all yalls help
  123. Axle Question! HELP!
  124. New here. have some ?'s
  125. performance steering?
  126. air temp sensor relocation???
  127. ebay heads
  128. Unclogging-Clogged Heater Tubes
  129. Replacing the front differential seal HELP
  130. staring problem after clutch replacement
  131. 3 quick ?s
  132. question
  133. GT40 lower intake EGR port?
  134. What part of my exhuast is leaking
  135. Anti freeze drip? Need help
  136. hesitation?
  137. MOVED: Affordable Track Car...1005 GT or Cobra?
  138. Manual Breaks on 89
  139. MOVED: cobras vs gts
  140. fuel injection?
  141. fuel injection Q?
  142. hesitation around 4800rpm
  143. MOVED: 1994 Cobra
  144. Changing timing and water pump gaskets
  145. What is this?
  146. 351 crank in a 302?
  147. cobra pushrods the same as stock ho?
  148. long tubes
  149. lifter tapping???
  150. brake leak question
  151. Lightened flywheel?????
  152. where can i get my block sleeved?
  153. MOVED: shift knob
  154. Edelbrock Performers
  155. trac lok
  156. not the clutch.. WHAT ELSE..?
  157. Tranny Question
  158. Which MSD will work best ?
  159. spun a bearing?
  160. Head Light Issue.
  161. turbo
  162. MOVED: anyone hear of J&P control arms?
  163. 5.0 Crate motor
  164. MOVED: Roll cage Requirements
  165. Question for guys that have worked on Cobra engines
  166. Did I kill my Heater Core?
  167. MOVED: Where to source an 8.8 rear
  168. phenolic spacers
  169. longtube headers
  170. MOVED: headlight problem!
  171. MOVED: 95 convertible turn into a hard top
  172. MOVED: Mostly gutted, what to do next?
  173. no power to coil
  174. MOVED: Timing gun question
  175. Gt 40 heads
  176. MOVED: viper motor in a fox?
  177. Removed Catalytic Converter Resulted in Power Loss
  178. low coolant light? Help?
  179. good springs for 18 inch wheels?
  180. no start problem
  181. MSD 2 step controller
  182. MOVED: 95 Cobra Bolt on Horsepower
  183. MOVED: what exaust?
  184. MOVED: dyno#'s updated with video
  185. MOVED: New Parts
  186. 600 double pumper??
  187. Zoom
  188. Bellhousing alignment?
  189. MOVED: What makes more power???
  190. water in oil. but dont know where its comming from.
  191. Headlight trouble!!
  192. MOVED: Tuning shops?????
  193. freeze plugs
  194. rear main seal..
  195. MOVED: Aftermarket cd speaker output left side only?
  196. No blinkers = crappy ignition switch!! Rant within...
  197. car stalled and wont start back uo
  198. GT40P heads and intake
  199. oil leak at distributor
  200. Front suspension help
  201. MOVED: need help with radio
  202. My car won't stop leaking coolant!! Help please!!
  203. Efi or carb
  204. engine complete, need help starting.
  205. 1990 GT turns over but won't start
  206. vibration at 3000 rpm
  207. Another fuel pressure question
  208. Front end conversion
  209. PINION SPLINE QUESTION
  210. MOVED: best things to look for when buying a new foxbody
  211. Sn Master Cylinder on a fox
  212. 94 computer question
  213. distrubitor difference?
  214. correct fuel pressure?
  215. Electric fan install questions?
  216. no felpro cobra gasket sets?
  217. Cam and Timing Chain Install Question
  218. 5 lug conversion axle question
  219. Fuel injection to carb conversion question
  220. throttle body
  221. lifter help!!
  222. one thing after another
  223. MOVED: vert curb weight
  224. MOVED: 3.73 gears yes or no??
  225. no fuel!!!
  226. MOVED: HO vs. NON HO
  227. SURGING IDLE AFTER WARMED UP. SMOG RELATED?
  228. Tranny question for you pros
  229. MOVED: Fox Salvage Yards?
  230. MOVED: Clutch type
  231. 87 - 93 exhaust on a '94?
  232. shifting hard when cold engine
  233. mustang dies at startup
  234. MOVED: What colors my car?
  235. Need help with top end decision.
  236. T5 fluid?
  237. e303 timing help
  238. Short???
  239. MOVED: mpg question
  240. air shocks
  241. MOVED: weight of fox vs. sn95
  242. seafoam
  243. What for optimum handling?
  244. intake manifold question
  245. MOVED: header studs, where to find???
  246. Heater Core, Radiator, or something else?
  247. Diff Play
  248. aluminum radiators
  249. Dart Shortblocks
  250. MOVED: 17"x8" Cobra R's
