- CHIPS
- 5.0 stalls above 4500 rpm?
- do i need to change the ECU??
- Oil in Upper
- Where does this connector go?
- Problem
- 351 "big spark plug" heads (small cc)
- Header and O/R H Pipe install, and now no bottom end?
- the 5.0 grew on me, Getting one, need some help. 347 stroker?
- Any Ideas?? Need Some Help!!
- 94 5.0 runs like ass
- Clutch peddle snaps. Need your help!
- question on water pump
- Front Pass Fender
- Stroker Motor Build!
- Oil Cap Under Pressure
- 86 5.0L AOD
- suddenly no oil pressure
- Power Steering Pump
- 1985 mustang gt car keeps dying
- Headlight issue
- Blinker relay? AUGH! *headdesk* Help me?
- quick question
- 650cfm carb to a 770cfm
- Brake problem
- 5.0 spring Swap.???
- tuning
- midpipe
- Anybody use a Bushings-in-a-Box kits?
- t5 transmission assembly problem
- How to tell when its time for a new Distributor Cap ?
- Suggestions for rear drag suspension
- Battery Dying issue
- 5.0 intake, turned 180* / head swap
- Stumbling from take off issues?
- removing emissions
- How much hp gain if you remove the cats?
- timing ?
- Oil leak?
- 94-95 spindles versus 96+
- Quick header to midpipe question.
- How to troubleshoot Oil Pressure issues?
- SUPERCHARGED MUSTANG, TOO HOT
- misfiring still!??!?! help
- air silencer removal
- 1983 5.0 With tranny problem
- Gas light come on when it wants to
- Any Ideas On This Problem?
- 87-89 instrument cluster
- Need Help!! what would make my car do this
- mass air conversion!
- Newbie With Engine Problem. needs help
- E85 setup on my 347?
- rough ride question?
- mass air sensor?
- Pinging
- k member bolt size
- cam shaft seal
- fuel pump relay help
- A/C compressor installation
- Will a 95 Cobra T5 fit in a foxbody?
- Gas tank (or around there) slurping sound?
- AIR tube removal and cleaning
- What's the tool you need to take the gear casing off on a 1992 Mustang GT?
- Changing oil pan gasket?
- what valve covers will fit
- exhaust/bumber question
- Suspension help needed
- A/C Issue Please Help!
- MORE 86 idle issues....
- Gauge cluster dissasemble
- What level of sound change can I expect with BBK shorties?
- water pump hose help...
- need a wiring diagram
- 5.0 Engine..
- Want to bump up the timing!!
- short belt with pulleys
- coolant reserve tank
- dropping in a big block need some help
- off road H pipe question
- Backfiring!
- Shifter adjustment?
- Flex-a-lite fan opinion
- Mass Air Meter
- 302 HO crankshaft vs regular 302 crank
- Need help installing Power steering bracket.
- Gear install? Whine?
- Temp guage fluctuation
- Close up pic of open notch trunk?
- 94 gt climate controls
- trick flow intake
- Exhaust Help!!!!!!!
- adjusting roller rockers
- Vacuum line replacements
- tko guys inside
- Solid Engine mounts vs OEM engine mounts
- deciding headers and mid pipe
- HOW TO DO VACUM CHECK
- front fender molding
- wiring harness ?
- Nitrous guys....please step in..
- Headers/H-Pipe but strange sound
- a/c ???? only blowing through window vents
- jerking during deceleration at highway speeds
- Swapping ECM (computers) AOD to T5
- 347 build plan
- Mustang Timing Question
- 1986 Mustang
- Exterior Suggestions
- valve covers
- crank shaft questions
- Need back space and tire size?
- Gas pouring out of carb
- Push start button help!!
- Upping the boost, again...
- coil resistance
- looking for a 302 block
- roller cam??? will an x303 cam fit
- AOD to C6?
- help with making my 5.0 faster
- holley system max II
- Clutch release cable.
- 1986 5.0L,
- Low battery voltage
- 24lb injectors and speed density
- 5.0 into a 2000 mustang..
- Throttle Body/EGR Spacers - 65 70 75mm?
- No start????
- wierd noise...cant pin point it
- parasitic loss help?
- Cylinder head bolt question
- Question about rocker arms
- Help with suspension
- MAF
- serious handling issues
- I want my moms mountaineer engine parts
- PUSH ROD QUESTIONS PLEASE HELP !!!
- Piston Stop at TDC?
- Tempermental Headlights/Fog Lights
- Engine Gets REAL Hot
- HELP!!!
- Lower Control Arms
- best carb and intake for 91
- What is the largerst you can stoke a 289 engine to? safely
- VIPER ALARM PROBLEM
- A/C delete? help??
- fuel problems (i think)
- Compression and power adder options
- Spark Plugs,Nitrous ?'s
- T-5z Question
- distributor not turning!!!
- 87 lx transmission questions
- Won't quite turnover...
- 05 Seats in 89?
- Buddy ran through some water, not it won't start... help!?
- fuel pump not shutting off
- Loss of power - poor acceleration
- HelP!!
- speedo not working
- Need your expertise! (mechanical or e-FAN)
- rhino linear
- How to remove winsheild wipers
- World Windsor Sr Rocker stud height
- slosh module
- Help in Columbus OH
- Thermostat
- how to remove door pin?
- B,E,F or comp cam?
- Smog UNdelete, etc.
- Compression Test? Tune Advice
- Iginition Upgrade Question
- (Tokico HP) or (KYB GR-2) ??????
- Some advice on suspension setup and rearend
- codes 41 and 91
- battery/ indicator light question
- Weird car acceleration
- Quick ? about 5.0 Swap
- Quick Wheel Fitment question
- POWER WINDOWS not working! 87 Convertible
- 1.7rr's clearance on e7 with e303?
- Tried searching... Anyone got a frame chart for the foxbody's?
- BBK SSIR on 94 cobra
- vortech question
- Smog pump bypass
- car runs hot?? wtf
- 306 engine build
- Header gasket?
- TICK NOISE
- Clutch Time :(
- Idling high after round of injector cleaner
- Stalling after H/C swap
- Need help with blower
- bounceing front end??
- need some advice on intakes
- gas drama
- 87 5.0 k-member conv. q?
- Will not idle no matter what!!!
- Fuel gauge sending unit
- Odd Ball Timing Q, and Still Backfire!
- Convertible top help
- Computer controlled timing
- 92 thunderbird or 83 mercury Capri
- Putting in New Suspension! No Rubber Sleeve?
- door chime problem
- Car not firing up
- fuel pump questions
- 93 5.0L 5spd hesitation
- Need help!
- belt routing- no smog, a/c or p/s
- Will these seats fit a fox???
- 2 Smog Pump Questions
- flat tappet to roller
- NEED HELP, Whats the problem here??
- Unequal or equal shorties?
- Cam question
- New 5.0 questions
- thinking of supercharging
- Black Headlight Covers???/
- Irractic idle with A/C on
- Fuel PSI gauge ?
- Base Idle help plz?
- MAF Conversion?!
- Thermostat Placement!
- ATTN: 1986 mustang owners
- Throttle body
- What tires size on 15x4
- Transmission Questions
- Drag Suspension Build? Recomendations?
- Finally....
- turbo or nitrous
- 390FE In My 1995 Stang
- Ignition timing question
- turbo help?
- C4 problems!!
- Quick Question
- Ignition upgrade for boost
- Speedometer Cable
- Idle problems
- 302 Master Rebuild Kit
- Code Help
- too much tranny fluid
- how much spray can i run?
- Valve Spring Question
- transmssion problems
- engines codes
- Pinion seal leaking?
- HELP! not firing all 8 cylinders
- FLEXPLATE???
- deciding between AFR 165's and GT40
- groved water pump pulley
