- Electric Fan Relay Help...
- nitto 555
- Cam question
- Stock 5.0 running rich, need help?
- next upgrade?
- MOVED: WOOHOO!
- help having problem.
- o2 sensor ? and a bolt ? to do with header install
- * RANT pg. 2*cleavor heads on windsor??? to do or not to do??
- 500hp 5.0??
- are these worth it??
- Just curious about you untuned folks.
- T5 Rebuild
- has anyone gone through them for an engine
- random peice of metal fell off my car today
- what gears do i have?
- Door/Window Issue
- Hesitation when at Operating temp!!??
- charging issues
- Looks like I have GT40 Heads
- lakewook bellhousing plate??????
- trans shift question
- Roadside issue
- Engine stalling - choking - cutting off
- Another Timing Question
- anyone try this intake??
- Tranny and Rear end questions
- injector ???
- 347 surging and pinging
- 1990 MUSTANG GT lamp conversion
- exhaust kit or just muff?
- Fuel pressure regulator size
- Tuning
- what tranny
- Signs of a bad intake manifold gasket?
- rollbar going in. seat delete?
- cobra vs. gt/lx
- fuel pump question
- Vibration after 65 mph
- mickey thompson et street......
- good estimate for rear seal replace?
- very small airfilter
- Timing Marks
- problem with warmup
- Help! problems with 5.0 install...
- A9P
- WHAT TIMMING YOU RUNNIN ON 347 STROKER?
- how to build a 302 efi??
- what cam?
- cam that doesnt require hci
- ahh help plz rear end is out of control
- pulling the 5.0
- Can I reuse?
- TPS voltage too high!
- new ege cupholder in sn95 ashtray?
- easy mods?
- MOVED: NMRA pure street rules
- MOVED: WTB! pms
- 89gt cobra no spark
- flushing the whole coolant system
- t5 swap from an AODE in a 94 GT conv.
- Losing coolant, heater core???
- 400hp and streetable?
- converting brakes an dtranny problems pls help
- clutch cable adjustment?
- Idle going crazy and jerking/bucking
- ive decided
- 2k RPM at 60, gears?
- 347 or 308
- lowered, tires rubbing
- New car, new path?
- general oil pressure
- I hit the jackpot!!
- 460 in a 93 notch
- bumper support HELP
- Installation?
- Clutch Help!
- Bought some GT40P's: a couple questions
- E Fan Setup's... What are you guys running?
- Progress:
- MOVED: what are you notch guys paying?
- MOVED: I highly recomend the "air adjuster". Fixed my idle and drivability problems
- still having problems
- Fluidyne Users HERE!
- identifying numbers on stock 5.0L
- BBK X-Pipe for AOD
- The best Heads for the buck???
- drag radials or slicks on ten wholes?
- These any good?
- Spark plugs
- MOVED: Car is Finalllyyyyy Painted, pics
- I gotta problem....
- Is this bad?
- 5.0 swap
- i need help
- hatchback VS notchback
- speedometer off
- If you think you know your AOD's, speak up.
- please help me!
- Low Coolant Sensor
- where is my window relay
- Unplugged Mass Air - Should car die?
- 1989 Power Door Locks
- OBD I OR II??
- Need help programming ZEX window switch
- AOD options
- EEC Tuning Tips UPDATED
- aod 1 piece input shaft question
- best intake manifold
- Engine rocking
- exhaust
- throttle body idel ?
- Where can I buy TPS Screws from?
- DRI WASH 'n GUARD(R) Special for Forum Members
- Car is burning rich?
- Air bag light
- AODE to AOD???
- 31-Spline 3.73 gears from an '01 Mountaineer?
- All the sudden, running like ****...
- CARB OR FI?
- Running Hot
- What else do I need to replace
- fuel pump questions....
- 15x8 prostars
- venom 400 control module
- sluggish when cold?
- probly an easy cobra question
- Bearing replacement
- Bearings
- Injectors rebuild
- List of what I need for H/C/I
- rubber plug?
- Aluminum driveshaft U joints
- k-member
- rad/coolant filters?
- main bearings
- diaphragm leak
- help with signals...
- gear drive timing, anyone using them here?
- Tranny Problem
- diameter of a 351w lifter bore??
- LONG BLOCK AND SHORT BLOCK????
- the t-5 finally broke
- MOVED: Hello!
- Best Underdrive Pulleys?
- 1993 fox body 5.0 vs 1995 5.0
- in need of a cam
- MACH 460 Problem!!
- quick question..help
- Burning smell
- line lock
- P/S relocation
- Will my car run ok if I put stock stuff back?
- What sizes
- Tranny Bellhousings
- Cam question
- Digital 6 hookup
- Bad Idle Part 1 *FIXED,MUST READ * New 5.0 Discovery
- new car with problem
- balancer
- cooling problem....
- IAC valve
- DOES STEADA..?
- ? about a hci w/ SD
- clutch cable..?
- MOVED: well....
- MOVED: fully built fox-would it be worth 10 grand?
- Exhaust question
- Carburetor Whistle
- Exhaust info
- what is the wheel horsepower on a stock 1994 5.0 AODE
- car wont start
- hci
- AODE transmissions
- switching to a carb?
- glasspack mufflers
- snow boost cooler
- Hatch Support shocks
- hey 5.0 guys
- Plugging MAP vacuum line
- a bad day
- 429 swap
- another smog pump question?
- Replacement bolt for the air box?
- Exhaust set up-Your Opinioin?
- What is the best H/C/I setup with: Vortech s/c,Full Exhaust, 3.73's, Auto 94 GT?
- Clutch
- windows wont work
- solenoid clicks an car doesn't start
- What size rivet for door actuator?
- Now I'm Pi$$ed!!!
- I need help identifying these parts
- good suspension
- need to replace front rotors
- c4 to aod
- 331
- turbo size
- wire size for fog lights...
- 89 LX 5.0 misses at cruise speed (only)
- N-41 & N-412 cam ?
- where can i get a washer for a 3g alternator to put the old pulley on
- Doner parts
- Could use some help
- Proform wiring help
- MSD TIMING RETARD BOX! help
- need help. pics included.
- TOP????
- black smoke!!!!
- MAF importance...
- Top Header-to-Hpipe bolts
- MOVED: Should i keep her?
- 95 mustang gt
- 30 39 42lb injectors??
- wat size piping
- dashboard swap
- cobra intake a direct bolt on?
- Thrust Bearing Cap question.
- rear axle seal??leaking
- How Much Horsepower - Just got a COBRA INTAKE MANIFOLD
- 351 in my hatch (yes ive searched)
- clutch pedal makes racheting noise
- Tranny Cooler
- coil
- Car seats
- car slugish
- axle tag
- Rough Idle after Smog
- Extremely Weird Problem
- Anybody using the Paxton SL (self Lubricating) superchargers?
- 83 mustang question
- vacume line question
- Transmissions
- fog light switch....
- Rear suspension question
- HELP: thermostat
- Clutch time
- rear again?
- carpet...
- Supercharger Options
- choked engine & back fires from the engine
- .550 lift is tough on retainer/guide relations
- Electric Fan Setup....
- Battery Relocation Please!
- 4cyl to 5.0 transmission question:
- AODE problems
- rear end
- anyone have a stock fuel pump?
- Turn the key and does not start???
- Transmission fluid??
