View Full Version : 5.0 Mustang
  1. Used prochargers
  2. no spark
  3. Top End Kit?
  4. Msd Distributor install help needed
  5. Driveshaft interchange on 92 5.0 LX 5 speed.
  6. Tail lights partially out on 94 Mustang GT
  7. Door lock key problems
  8. Slipping in park
  9. Door tension spring for lower roller 1990.
  10. How many miles is too many to start modding?
  11. sealing downpipe
  12. Cam Install??
  13. 130A Alternator?
  14. Anyone running 18" wheels? Already Searched.
  15. What thermostat you guys running?
  16. rear end ?
  17. idle problem persists!?
  18. Clutch Pedal and Starting
  19. Equal length vs regular shortie headers
  20. Fender allignment
  21. Idle Issue
  22. Wiring diagram for '85 Mustang 5.0?
  23. PCV Valve 'Grommet' Question
  24. total weight of mustangs
  25. 87 mustang gt back fireing ??
  26. Buddy Having Problem Starting Car
  27. clutch cable clip
  28. doggy with 24 pound injectors help
  29. a/c lines
  30. Fog Lights
  31. Help Me Choose a Cam :)
  32. please help me someone
  33. belt question
  34. please help me someone
  35. Timing question..
  36. now what do i do?
  37. electrical help... i f#*ked up =(
  38. help, adjustable timing pointer
  39. exhuast!!??
  40. gt40p milling
  41. Cobra intake install question
  42. What should I start with?
  43. edel performer rpm heads
  44. 95 not idling right?
  45. Clunking Noise
  46. 2 Questions
  47. Where to mount msd 6a box
  48. code 94
  49. 1984 Small starting problem
  50. HID Dual Beam Headlight Conversion Kit for 87-93 Mustang (9004 Bulb)
  51. 5 point harness.
  52. 5.0 stang motor vs 5.0 truck motor
  53. wheel hop! need input
  54. Electrical Gremlin
  55. 5.0 caburetor throttle linkage
  56. Possible Clutch Issue
  57. TKO 600???
  58. belt size when p/s pump removed
  59. EFI dizzy and carb motor timing advance?
  60. Nitrous Question?
  61. Timing Adjustment Question -total timing
  62. gauges
  63. CARFAX ANYONE?????????
  64. 60lb cal Mass Air Meter
  65. aod guys take a look
  66. Neutral Saftey Switch???
  67. Anyone fab up new heater tubes??
  68. C/C plates, LCA's and diff fluid swap...
  69. Power Steering Pump? & Weird Noise?
  70. Should I Buy this?
  71. What is the best cam with the stock bottom end that can still pass CA emissons?
  72. 87 mustang gt help and qustions please idle ? and gauges
  73. cluster pin-out
  74. ignition question
  75. HEADS
  76. t5 help
  77. solid motor mounts for vert
  78. What flywheel is this?
  79. Fuel Injection
  80. Need some advice
  81. gauge lights
  82. Problem with temp and idle
  83. Starting issue
  84. Is anyone familar with this set-up. Scat 331
  85. What brand headers do I have.
  86. oscillating idle?
  87. What does it take and how
  88. rebuilding engine
  89. 1987 mustang gt 5.0 ho help please wont stay started
  90. voltage regulator
  91. Ticking at WOT
  92. aftermarket fuel pump?
  93. 351w Headers size question
  94. ford racing injectors
  95. battery relocation help.
  96. Motor Teardown Results
  97. Is fith gear in a t-5 suppose to make a faint noise?
  98. Surging idle better but not fixed
  99. Mustang rims
  100. Tire/Drag Radials ?
  101. Detonation at idle.
  102. afr heads
  103. Head suggestions setup.
  104. Well
  105. Wires under hood
  106. EFI Tuning/motor questions
  107. rear/cargo shocks cover
  108. Gasket ?
  109. driver seat rocks back and forth
  110. steering prob :/
  111. Power window problem
  112. Need Advice
  113. Heffin Idle Roll, Throttle Body Location Random Click = Perfection? Help!
  114. First startup tips
  115. Horsepower Help
  116. TPS Adjusting? Voltage how?
  117. ticking and thumping
  118. Replacing Fuel Injected Engine w/ Carburated.
  119. will this work?
  120. Rear Diff ???
  121. tubular k member fitment problems?!?
  122. 3g alternator
  123. 90 LX wont idle when warm
  124. few questions furing a raddy pull.
  125. arp head stud question
  126. Need help...Intake gasket leak?
  127. EFI swap wiring questions
  128. 2 elbows on pcv?
  129. Lowering 88 GT with stock springs
  130. Exhaust quesiton.....???
  131. EFI Dizzy Wiring
  132. Crower 15510 or Comp xe264
  133. 88 lx maf conversion
  134. 86 Gt 5.0L motor build
  135. need help
  136. spark plug diference bank to bank new 331 stroker with t5 swap
  137. Want to bypass smog pump... any issues?
  138. very high idle help!
  139. EGR block off back of cylinder head
  140. New engine questions
  141. intake and heads
  142. Another Radiator Question
  143. Tailights?
  144. Which head gaskets?
  145. Do they make a speedo cable that is quiet?
  146. Anyone have engine specs for a 302 H.O stock
  147. clutch adjustment on 95?
  148. Looking for advice!!!!!!
  149. fuel pressure on a stock 94 cobra?
  150. pcv
  151. Water Temp Installation
  152. 95 GT sway bar diameter?
  153. Knocking in door panel...
  154. Need help with timing...
  155. Broken Horn
  156. starter bolts
  157. 150 shot jet sizing
  158. Can anyone help?
  159. link bar lifter
  160. rattle
  161. H pipe for Ford Racing Shorty headers
  162. 1988 PCV Modification
  163. Advice on rebuild or new
  164. CEL
  165. Figure this one out cause i sure cant!!
  166. ticking sound
  167. Need Some Help, Adjusting Solid Roller Rockers
  168. Wheel/Tire fitment
  169. Anyone running BBK intake w/AFR heads?
  170. more problems!!
  171. Cam for Auto
  172. Grill where the body front body kit bends in?
  173. vibration problem
  174. *Help* Removing Timing Chain
  175. Flowmaster 50's or Magnaflow???
  176. Window motor!
  177. Sub Frame Connectors
  178. 9/16 or 5/8
  179. air conditioning
  180. What Kind? How Much? & Advice!? Please
  181. Charging Problem
  182. bushing in t5
  183. ran a KOEO and KOEO test now what?
  184. evap core removal
  185. help with this fusebox
  186. Autometer pillar mount
  187. interior wire problems
  188. best spark plugs
  189. Gas & Oil Gauge Problem
  190. I have a random miss
  191. Speedo Drive Gear
  192. Noob trying to Upgrade
  193. Wipers, Radio, and Power windows not working
  194. Fuel Pressure Regulator Bad?
  195. Help/Advice
  196. MSD ignition box
  197. Fuel pressure test!
  198. Fuel pressure test!
  199. 1979 K MEMBER QUESTION?
  200. HELP!!
  201. Timing and what not
  202. fuel pump wont fit
  203. Wont idle!
  204. basic H/C/I help
  205. ignition lock
  206. need help with my trans
  207. Engine swap question.
  208. Rear bumper question for 88gt
  209. waterpump
  210. New Guy here, first post.
  211. oil leaks. gaskets. pan removal ,etc
  212. quick wiring question
  213. This sound like a good deal to you??? (5.0 LX content)
  214. problem??
  215. Electrical Problem Plz help
  216. hypothetically speaking...
  217. water pump changing
  218. gastank gas tank removal
  219. just bought a 94 gt
  220. front and rear spring
  221. incerts
  222. Stang runs but doesnt RUN
  223. incerts
  224. car died and wont start need help bad
  225. Help ID this GT40 lower
  226. questions about d.s.s 308
  227. CAR DIED WONT START!!! HELP ASAP
  228. how much hp
  229. Running with open shorties
  230. trick flow upper intake hp?
  231. trick flow upper intake hp?
  232. How to fix these codes 81 82 95?????
  233. TPS set at .98 problems
  234. Fuel Pressure psi?
  235. car dies when warm.
  236. fuel gauge not working
  237. replacing rad support
  238. new rear end and disc brakes
  239. Bell housing removal
  240. Need help on edelbrock heads need advice
  241. Rocker arm movement
  242. Which 02 sensor to get?
  243. Frame rot in front end.
  244. threaded insert ?
  245. t56 in a 94gt
  246. Center Console
  247. rebuild to a 347 stocker from a 302
  248. just when i thought i got lucky
  249. Disappointing Dyno Numbers
  250. Rear Lower Control Arms
